| Vastu for Water Tank It is important to place water bodies in Vastu friendly manner to preserve resources and energies. Under ground water .. |
| Preventive Measures for Leakage from Water Tank The following measures should be taken during construction of water tank to prevent the leakage. These preventive meas |
| Water Storage Solution Storage of water in proper way is essential for drinking, cleaning, bathing, cooking purposes in our day-to-day life. .. |
Which type of chemical is recommended for the protection of dampness ? The following table expresses the type of coating recommended for the protection of Dampness: |
Reasons of dampness
The reasons of dampness in the building are following:
1. Bitumen /Tar- felt coat on RCC slab is not proper or is |
