Cost Estimate
Cost Estimate
Sat Sep 13, 2008
Arun Kumar Saini
Topic: Cost Estimate
Dear Sir/Madam,
We have a plot of area 2720 square feet in Delhi (near Najafgarh). We want to construct ground floor with atleast 3 bedrooms, 2 bathrooms attached with bedrooms, 1 kitchen, 1 drawing room and lobby. I want to know the estimated cost of this house including the labour and construction material.
Also could you please tell me what would be the cost of constructing a basement for this area?
Arun Kumar Saini
Tue Sep 16, 2008
Post subject: Detailed Cost Estimate
For calculating the cost of the building you can take help from the cost estimator tool at the website gharexpert.com
I can also supply the detailed estimates as per the tariff below.
Up to 2000. Sq. feet area = Rs.1.50 per sq. feet.
From 2001 to 5000.Sq. feet area= Rs.1.25 per sq. feet.
From 5001 to 10000.Sq. feet area= Rs.1.00 per sq. feet.
Above 10000. Sq. feet area = Rs.0.75 per Sq. feet.
If you want detailed quantity estimate and detailed cost estimate than you have to supply the drawings i.e. plan, elevation of the building etc.
I had provided similar estimates before as you can see at the link below.
http://www.gharexpert.com/ques_ans/Ans_To_ques.aspx?QID=571&CatID
Detailed estimate can save your thousand of rupees and time. Some benefits of detailed estimate are mentioned below:
From detail estimate you will get the information about all type of materials required for the work and the information about the actual quantity of all the materials required. You can use this knowledge to make agreement with the supplier in advance to avoid fluctuation in the market.
If you do not know the estimated quantity of material required to build your home, the contractor may charge more amount to do the same work. With the detail estimate sheet you can cross check the quotation provided by the contractor.
With the help of detail estimates we can arrange the materials according to the needs at site. This will avoid unnecessary storage of materials, save the wastage of materials and blockage of money. It will also save unnecessary carriage and time.
With arranging all the materials according to need it will help in smooth working and to avoid wastage of labor.
This will help to arrange funds according to requirement.
Detail estimate also give the specification of the material required for the construction which will help in checking of the quality of the materials at site.
If all the materials and labor will be arranged according to need it will help for timely completion of construction work which will save the expenditure spent on storage, watchman etc.
Timely completion means timely use of house.
2322
what is the cost estimated to fullfil .
Last answer on 6/29/2012 8:16:15 PM. by
naresh khari
5765
Estimation
Last answer on 7/3/2020 10:09:18 PM. by
ksk
ksk
2128
Looking for expert advice
Last answer on 9/16/2014 11:09:25 PM. by
Ced Bowen
Ced Bowen
16320
COST ESTIMATE OF BOUNDARY WALL PER FOOT
Last answer on 7/4/2020 3:35:51 AM. by
sira
2004
Cost Estimate
Last answer on 10/20/2015 12:55:10 PM. by
Er.S.K.Jain
ani
1582
Construction Cost Estimate
Last answer on 5/3/2016 12:17:22 AM. by
Nazir Khan
1730
cost estimate for new commercial complex
Last answer on 4/6/2016 11:49:51 AM. by
Prashant Sinha
4888
Cost estimate for raising compound wall and shops
Last answer on 1/6/2012 2:32:27 AM. by
ravi at Dalmia
mrakesh
3289
Sample layout for building flats on my plot, and rough cost estimate
Last answer on 10/21/2012 11:03:49 PM. Forum started by
solemnamritanshu
1897
Cost estimate
Last answer on 4/4/2013 11:48:49 AM. by
Ketul Vaishya
1734
Time and Cost Estimate request for modification work
Last answer on 7/2/2013 5:07:21 PM. by
Raj
Raj
18327
Last answer on 7/3/2014 2:27:06 PM. by
Muhammad Rizwan
ragha
2655
cost estimate
Last answer on 10/21/2013 1:38:12 PM. by
chatrapatidas
2469
Cost estimate
Last answer on 11/18/2013 10:55:38 AM. by
Bharat Mathur
1272
I have a bungalow in which I stay presently size 1200 sq.ft. area. I want to bui
Last answer on 6/15/2016 12:10:41 PM. by
ARVIND
2094
Hi Experts,I live in Bangalore. I have a requirement to construct sump of capaci
Last answer on 7/4/2020 2:50:00 AM. by
Jagadesh
Need Construction cost of G+1 house in Sanghvi, Pune
Last answer on 6/21/2016 9:15:47 AM. Forum started by
rakesh
1316
thanks. but i need house plans of 900 sq.ft.and mover over can we able to contra
Last answer on 7/27/2016 2:33:57 PM. by
ram
1920
I want to construct underground water tank of 6'x6'x6'. Please give cost estimat
Last answer on 7/18/2013 3:45:44 PM. by
Neeraj Sharma
Neeraj Sharma
2336
