| Specification of Steel Generally steel is much durable hard, strong, and made of iron and carbon. The steel should be free from cracks, surfa.. |
| How to ensure weight of steel members? Before you purchase mild steel members for construction of your house, you must know weight and cost of steel members .. |
| Type of Steel Bars Different steel bars are recommended for their relative tensile stresses.Steel bars are major components of constructi.. |
Labor Guideline for Steel bars in RCC Every process needs proper guideline and expert person or team to manage in construction or in any field. Even working.. |
| HSD Steel Bars (High Strength Deformed Bars) To ensure the strength and quality of your house construction, utilize HSD Bars since they are produced in form of col.. |
| Precautions while purchasing steel window grills Steel is the most important element in construction of a home or building. It must be free from cracks and surface fla.. |
| Steel Roofing Steel roofing is tough, stable and easy to install. These words are enough to describe steel roofing. So here are some.. |
| Specification of Fine Aggregate/Coarse Sand Fine Aggregate may have more impact on the strength of the building than cement. This article explains the guidelines .. |
What is binding wire Binding wire is important material in construction process, especially in RCC work. What is binding wire and what are.. |
| Sanitary Appliances And Their Specifications Sanitary appliances are fittings used for collection and discharge of soil or waste matter. These appliances may be gr.. |
