Tue Apr 19, 2011 | Post #1 | sabina vanjani
Join date: Mar 2008 | A lion faced plot is better for business organizations.
Sabina Vanjani | |
Tue Apr 19, 2011 | Post #2 | Rashmi
Wanted to know if with any rectification it can be used as a residence. Thanks Rashmi | |
Wed Apr 20, 2011 | Post #3 | sabina vanjani
Join date: Mar 2008 | If you can divide the plot into a square plot and let go of the remaining area it can help
Sabina Vanjani | |
Mon Apr 25, 2011 | Post #4 | alagu chendur murugan
Join date: Mar 2011 | A land tilt of 20 degrees, off square by 20 degrees, is acceptable. If the plot is rectangular, it is better that the longer sides run north to south rather than west to east. The best properties are either square or rectangular. If the plot is not a perfect rectangle, it is best if at least the southwest and southeast sides of the land are at 90º angles from one another. The southwest side of the quadrilateral should definitely not be extended past the southeast side, even if that means giving away a portion of the plot. Land that extends past the northeast side of the quadrilateral, however, brings wealth, happiness, and good name. Land extending on the northeast side is very good. Extensions on any other side are inauspicious. Extensions of the northwest side will cause you to lose money and peace.
Would suggest to go for a rectangular than a square so that you can use most of the area for construction. | |
Vastu Shastra-Construction Questions (39) | |
