hi,I need a ground floor plan for 1800 sq.ft porche with 3bhk with pooja room,
Mon Jan 27, 2014Total posts : 1
arunji.mech
arunji.mech
Topic: hi,I need a ground floor plan for 1800 sq.ft porche with 3bhk with pooja room,
hi,I need a ground floor plan for 1800 sq.ft porche with 3bhk with pooja room, store room, stairs inside.plot size 40 x 80 sq ft.
Tue Jan 28, 2014Post  #1
Dear Arunji
1299
Hi, I would like to construct East-facing house in 50 * 72 sq ft (50 length & 72
Last answer on 5/17/2016 12:06:23 PM. by Beenu Phogat. Forum started by Shalini
2354
Electic wires
Last answer on 1/17/2014 12:15:51 PM. by S L Gupta (Civil Engg). Forum started by rajesh
567
Need a plan for plot size 45ft roadside and 35 ft depth facing west, single floo
Last answer on 2/19/2021 5:39:57 AM. Forum started by Kiran Tankasali
6643
West house plan for 1800 sq ft
Last answer on 1/18/2013 1:28:51 PM. by Gunjan Utraja. Forum started by sainadh
1922
Regarding Construction Cost
Last answer on 10/20/2015 11:33:37 AM. by S L Gupta (Civil Engg). Forum started by Sagar Hande
5935
Help required: House plan for 33 x 50 Sq ft North facing plot
Last answer on 7/2/2020 10:07:28 PM. by S L Gupta (Civil Engg). Forum started by sheeja
5563
Having a plot of 30'X40' south facing, want to know floor plan up to 700 sq ft w
Last answer on 2/16/2019 2:25:41 AM. by Amit Hasija. Forum started by viairsung
6420
House plan for 38 x 40 Sq ft plot
Last answer on 2/12/2013 1:05:30 PM. by Anupam Anurag. Forum started by sheeja
Construction House plan require for G+1 for plot size of 31* 53
Last answer on 11/29/2016 6:16:06 PM. Forum started by baji
5031
i need a rough floor plan for my south facing plot 40 x70=2800 sqft ;Gf- complet
Last answer on 8/23/2013 12:08:10 PM. by S L Gupta (Civil Engg). Forum started by H R SATISH
1652
New building plan 1200 sq.ft
Last answer on 6/29/2021 7:56:44 AM. by Beenu Phogat. Forum started by Sathesh
1417
Please sent me house plan s for 3BHK Ground floor with out car parking of built
Last answer on 5/26/2016 3:30:43 PM. Forum started by sunahar ali
17045
Estimation for ground + 2 floor
Last answer on 2/27/2015 10:52:31 PM. Forum started by sboloor
2062
I am planning to construct an house in Guntur and it is a 2 road bit and dimensi
Last answer on 3/17/2015 11:46:59 AM. by seema tyagi. Forum started by Narendra Kumar Saranam
2131
construcion of a new house
Last answer on 2/18/2014 12:15:33 PM. by S L Gupta (Civil Engg). Forum started by pmlaks
3845
Individual House Plan for 2200 Sq Feets
Last answer on 4/26/2021 12:30:53 AM. by Gunjan Utraja. Forum started by vishal
1070
2325
419
2259
1375
297
260
390
258
241
238
203
213
207
210
209
214
220
225
201
What is acre
Preliminary
Compact
Compact Hi-Tech Kitchen
Pooja
Pooja Room Vastu
Pooja
Pooja room designs in wood
