Thu Jul 26, 2012 | Total posts : 3 |
| Topic: is it recommended distance between two pillars is 17'.0
Hi Sir, we are constructing a house, is it recommended distance between two pillars is 17'.0.
Please find the attached house plan. |
Thu Jul 26, 2012 | Post #1 | S L Gupta (Civil Engg)
Join date: Mar 2008 | Dear, I saw your plan, You can lay one more column between these two column or Lay beam on column according to design with roof slab or you can make the load bearing wall between these columns. These are three option you can adopt one of them. However, it is strongly recommended that you hire the service of a structure engineer who would design the structure based on the soil's load bearing strength. The engineer would also help you design an earthquake resistant design | |
Fri Oct 14, 2016 | Post #2 | Vishal Thakur
Join date: Oct 2016 | Post subject: Distance between pillars
Constructed new house a year back.. open plot area 30ftx60ft = 1800sq fts (200 sq yards).
Here is my question..
On first floor engineer constructed 9 inch red brick wall on 5 inch RRC slab without laying column on ground floor as shown in diagram. please let me know is there an issue in future because of 9 inch wall load on slab? if yes then what is the solution for it.
our plan to add +2 floors in future.
Appreciate your quick response.
Thank you, Vishal singh
Mon Oct 17, 2016 | Post #3 | S L Gupta (Civil Engg)
Join date: Mar 2008 | Dear vishal There is any error in floor plan G +3 that is not opened for giving reference. | |
Brick Walls, Pillars and Structure-Construction Questions (39) | |
Articles that might interest you! | | Finishing recommended for wood ceiling There are many type of ceilings are provided such as stretch ceiling, wood plank ceiling, or steel ceiling. But do w.. | | Brick Pillar To construct the veranda brick pillars are constructed to take the load of the roof of veranda. | | Construction of Brick Pillars The brick pillars should be designed according to the weight coming on it.
| | Glass window finishing materials For glass window, verity of finishing martial available in the market. Here is a complete description of all the finis.. | | Wooden board recommended size for wooden ceiling Going for wooden ceiling? Does your labor, contractor or you know what the recommended size of wooden boards for ceili.. | | Septic Tank, It’s Principle and Guidelines Septic tanks or soak pits are useful for disposal of waste in the areas or houses where public sewerage system is not .. | | What is recommended method for opening in load bearing masonry walls? .Vertical clear distance between openings should be less than 60cms.
.Horizontal clear distance between openings shou.. | | Tips for Oil Bound Distemper If you want to decorate your home with high quality paint and finish, oil bound distemper is the right choice because .. | | Terrazzo flooring (Mosaic or Marble chip flooring) Terrazzo flooring is popular for residential as well as public buildings since it is not slippery when wet.
| | Kitchen Ideas Make your kitchen both friendly and well-organized with these creative decorating ideas. Kitchen is a one of the most .. | | What are various types of glasses used in doors? Types of glasses used in doors-Clear window glass, Plate glass, Prism glass, Quartz glass, Processed glass....... | | What are advantages and disadvantages of folding doors? Advantages of folding doors- Easy to install,washable, durable, superior sound damping. Disadvantages-sensitive to har.. | | What are various designs available in wooden doors? Designs available in Wooden doors..... | | What is standard size of internal folding doors? Size, Thickness and Weight of Internal Folding Doors....... | | What affects the life of doors? What can we do to increase the life of the Wooden doors? Tips to increase the life of Wooden doors.... | | What is the standard size of frame for Plastic/PVC doors? Plastic Door frame size carrying one or two shutters...... | | What are various frames recommended for Plastic/PVC doors? Frames for Plastic Doors.......... | | Which place is appropriate for sliding door? Appropriate places for sliding doors-Bathrooms, Backyards, Commercial structures........... | | What are various frames recommended for glass doors? Frames for Glass Doors-Wooden frames, Steel frames, Aluminium frames...... | | Which place is appropriate for folding doors? Appropriate places for folding doors-Homes, Offices, Guest rooms, gives attaractive and stylish look........ | | What are the various accessories recommended for folding doors? Accessories for folding doors- Door Handles, Door Fasteners,Door Viewers....... | | What affects the life of doors? What can we do to increase the life of the Plastic/PVC doors? Tips to increase the life of Plastic doors.... |
