water leakage
Fri Aug 10, 2012Total posts : 5
sunil santhumayor
sunil santhumayor
Topic: water leakage
I am almost done with the construction of my house and due to the recent rains a lot of water leakage is evident . the builder says this is due to the Saja ( papapit )
and has fixed the problem . it has not rained as heavily after so there is no way of finding out if the problem is solved
1 could any one help to find a solution
2 is there a way i can be sure before i take possesion as the only way i see is to wait for next year rains
Attachments: 110720122051.jpg on Fri Aug 10, 2012,
110720122053.jpg on Fri Aug 10, 2012,
110720122052.jpg on Fri Aug 10, 2012,&n
Sun Aug 12, 2012Post  #1
Ravi
Ravi
Post subject: Water Leakage
Hi Sunil,
Please let me know, what is the above portion of the ceiling which is showing leakage, is it terrace or a bathroom or a overhead water tank ??
Ravi
Sun Aug 12, 2012Post  #2
sunil santhumayor
sunil santhumayor
Post subject: water leakage
thanks Ravi for replying cant believe 200 viewers and only reply from you i though this was a professional website
 the leakage is mostly on the first floor have attached more pictures to make it clear as well as a few areas on the roof where teres dampness
Attachments: suniliphonejul2012 128.JPG Sun Aug 12, 2012,
suniliphonejul2012 122.JPG Sun Aug 12, 2012,
suniliphonejul2012 115.JPG Sun Aug 12, 2012,
suniliphonejul2012 125.JPG Sun Aug 12, 2012,
suniliphonejul2012 111.JPG Sun Aug 12, 2012,&n
Tue Aug 14, 2012Post  #3
DearSunil
          I under stand thatyou want to test the roof for leakage in the absence of  rain. You should arrange  pipe, water pump and sprinkle the water on roof . For better testing you can close the out let pipe of roof for some time, if any leakage is there that can be seen.
Fri Jun 29, 2018Post  #4
HansRakes
HansRakes
A few years back I came across this problem, it is because of wrong fixing of pipes at the time of construction .i have seen some techniques for fixing this kind of problems in bestessays com writing services. You can also check them if you need any further help .this problem arises when there is a breakage in pipes too. So check them and fix with a quality material.
Sat Jun 30, 2018Post  #5
Thank you sir
Last answer on 12/27/2018 12:50:53 AM. by S L Gupta (Civil Engg). Forum started by Y Mitran
977
Last answer on 6/23/2015 12:57:08 AM. by JAI PRAKASH. Forum started by Mohd
892
There's a basement space in a building and it locates at backyard of lower level
Last answer on 10/24/2013 11:34:35 AM. by S L Gupta (Civil Engg). Forum started by parth
955
APP membrane
Last answer on 10/14/2016 1:56:06 AM. by chethan. Forum started by chethan
946
Water Leakages in Cellar Building
Last answer on 10/19/2015 2:52:35 PM. by vijay. Forum started by Bharat Kumar
602
Water leakage from roof concrete
Last answer on 7/11/2016 3:19:23 PM. by S L Gupta (Civil Engg). Forum started by Aravind Rahul
1235
Last answer on 6/7/2013 11:27:36 AM. by S L Gupta (Civil Engg). Forum started by nagaraju kakani
2724
2110
Water leakage from the Swimming Pool
Last answer on 2/22/2019 2:13:42 AM. by S L Gupta (Civil Engg). Forum started by S. K. Agarwal
423
sir my i have problem in bath room 1st floor bathroom seen in groundfloor ceili
Last answer on 1/31/2017 12:01:05 PM. by S L Gupta (Civil Engg). Forum started by raj
547
Last answer on 2/13/2017 5:13:13 PM. by karthik. Forum started by Vineet Sethiya
1196
How to use Feng Shui to attract wealth?
Last answer on 12/27/2013 5:13:21 PM. Forum started by soni gupta
1127
leakage.
Last answer on 7/21/2013 3:08:37 PM. by chethan. Forum started by chethan
5277
What precautions should be taken while constructing leakproof Slab
Last answer on 5/9/2011 5:23:28 PM. by Moreshwar Kelkar. Forum started by tiwari_p_k
921
Water proofing method
Last answer on 3/13/2015 1:44:42 AM. by JAI PRAKASH. Forum started by ringwang
1580
How to arrest leakages through expansion joints.
Last answer on 11/20/2009 10:16:24 AM. by Girish. Forum started by Jagadesh Babu
1185
1982
1214
Last answer on 5/29/2014 7:25:05 PM. by Vinay. Forum started by Vinay
20241
Best Color Combination for Modular kitchen Cabinets and walls
Last answer on 2/22/2019 4:48:02 AM. by basil. Forum started by raghuam
I am constructing a Studio house with 3 wooden doors (East, North and South sid
Last answer on 2/22/2019 2:21:26 AM. by S L Gupta (Civil Engg). Forum started by Harikishan
Please suggest good interior designer in Hyderabad for a studio house in 25’x 25
Last answer on 2/22/2019 2:18:59 AM. by S L Gupta (Civil Engg). Forum started by Harikishan
3717
Use of Solid Concrete Bricks
Last answer on 2/22/2019 2:16:47 AM. by S L Gupta (Civil Engg). Forum started by Kinley Tshering
1107
Last answer on 2/22/2019 2:16:04 AM. by S L Gupta (Civil Engg). Forum started by Punitha
15379
Last answer on 2/22/2019 2:15:37 AM. by S L Gupta (Civil Engg). Forum started by sonu
1993
Last answer on 2/22/2019 2:14:58 AM. by S L Gupta (Civil Engg). Forum started by silochonie
236
My contractor keep on insisting FE 500 for our new home. My wife is a civil engi
Last answer on 2/22/2019 2:14:14 AM. by S L Gupta (Civil Engg). Forum started by Rekha R
2110
855
What will may be full construction estimate cost plot size of 25*45, pl send me
Last answer on 2/22/2019 2:13:04 AM. by S L Gupta (Civil Engg). Forum started by mahendra kumar dutta
28
Last answer on 2/22/2019 2:12:21 AM. by S L Gupta (Civil Engg). Forum started by Ravi
831
plumbing
Last answer on 2/22/2019 2:11:43 AM. by S L Gupta (Civil Engg). Forum started by ANKITA MADA
1622
estimate for 3 storey building in pune
Last answer on 2/22/2019 2:11:10 AM. by S L Gupta (Civil Engg). Forum started by ksp
1092
vastu advice
Last answer on 2/22/2019 2:10:25 AM. by S L Gupta (Civil Engg). Forum started by shilpa
1893
I am selecting parrot green laminate for my kitchen, what other colour will comp
Last answer on 2/22/2019 2:09:57 AM. by S L Gupta (Civil Engg). Forum started by pranju11
1739
Last answer on 2/22/2019 2:09:21 AM. by S L Gupta (Civil Engg). Forum started by jitu
1949
Road facing House
Last answer on 2/22/2019 2:08:47 AM. by S L Gupta (Civil Engg). Forum started by vardhan
3276
main door vastu question
Last answer on 2/22/2019 2:07:40 AM. by S L Gupta (Civil Engg). Forum started by sujatha
124
23X60 WEST FACING 3 BED ROOM DOBOULE FLOOR HOUSE DESIGN AS PER VASTU UP STAIR FR
Last answer on 2/19/2019 11:24:30 PM. by S L Gupta (Civil Engg). Forum started by RAJANI KANTA PATRO
674
I have a piece of land 25'width/50'length.Pls. suggest me for home making archit
Last answer on 2/19/2019 11:23:49 PM. by S L Gupta (Civil Engg). Forum started by ashish panchal
Preventive
Electric
60
60 Tips to Save Water
Vastu for Water Tank
Water for Construction
Rain
Rain Water Harvesting
Garden
Garden Fountain
Adding a fountain to your garden will invite birds and butterfly to visit your garden. The sound of water running can ..
