Fri Mar 17, 2017Total posts : 1
Sanzana Hosen
Sanzana Hosen
Topic: installations of slab casting?
How to install electrical conduits and sanitary fittings during slab/roof casting?.
Sat Mar 18, 2017Post  #1
        Lay the electrical conduits on the the top of MS Steel bars and bind them properly with binding wires.
Check the gauge and diameter of pipe with its quality before laying the pipe in slab.
the joints of pipe with fan hook and light point should be tight so that can not disturbed during laying the concrete.
1865
stair construction
Last answer on 3/7/2017 9:56:24 PM. by S L Gupta (Civil Engg). Forum started by Sanzana Hosen
1997
casting of slab
Last answer on 7/29/2014 12:58:28 PM. by S L Gupta (Civil Engg). Forum started by ishaan
1767
how much cast
Last answer on 12/11/2020 12:20:05 PM. by JAI PRAKASH. Forum started by PRAVEENKUMAR
41
iNtEr cAst lOvE mArRiAgE 91-8769373431 lOvE BaCk SpEcIaLisT
Last answer on 12/14/2024 1:34:53 AM. Forum started by rupeshji
30
,,!iNtEr cAst lOvE mArRiAgE 91-8769373431lOvE bAcK sPeCiAlIsT
Last answer on 12/14/2024 1:51:46 AM. Forum started by rupeshji
29
InTEr cASt 918769373431 @ LoVe PrObLeM soLutiOn
Last answer on 12/14/2024 1:57:32 AM. Forum started by rupeshji
24
Last answer on 12/14/2024 11:26:13 PM. Forum started by rupeshji
51
,,!iNtEr cAst lOvE mArRiAgE 91-8769373431 lOvE bAcK sPeCiAlIsT
Last answer on 12/14/2024 11:32:23 PM. Forum started by rupeshji
49
InTEr cASt 918769373431 @ LoVe PrObLeM soLutiOn *itaLy
Last answer on 12/14/2024 11:34:52 PM. Forum started by rupeshji
23
Last answer on 12/17/2024 12:42:30 AM. Forum started by rupeshji
24
Last answer on 12/17/2024 12:44:48 AM. Forum started by rupeshji
37
Last answer on 12/17/2024 12:49:43 AM. Forum started by rupeshji
29
Last answer on 12/18/2024 10:25:26 PM. Forum started by rupeshji
28
Last answer on 12/18/2024 10:29:20 PM. Forum started by rupeshji
21
Last answer on 12/18/2024 10:31:01 PM. Forum started by rupeshji
21
Last answer on 12/19/2024 10:45:47 PM. Forum started by rupeshji
32
Last answer on 12/19/2024 10:45:54 PM. Forum started by rupeshji
26
Last answer on 12/19/2024 10:46:01 PM. Forum started by rupeshji
169
62
27
23
24
22
21
23
17
23
22
26
23
26
23
27
21
23
Hardwood
Hardwood Flooring and its Installation
Hardwood flooring is one of the expensive yet elegent flooring option. Its installation is not that typical but still ..
Cupola installation tips
Tips for cupola installation
Vinyl
Vinyl Flooring
How to Install a Sink
Installation of kitchen sink requires just few tools,material and a beautiful sink according to your needs. Read the s..
Copyright 2007- 2025 GharExpert.com All rights reserved.
