sir, what are the precautions need, to make a swimming pool on the roof.
Sun Feb 19, 2017Total posts : 1
Gagan Matharoo
Gagan Matharoo
Topic: sir, what are the precautions need, to make a swimming pool on the roof.
Mon Feb 20, 2017Post  #1
        Next step is water proofing the roof slab to prevent the seepage in the roof. A proper water proofing treatment should be done before building roof swimming pool. Chemical based water proofing treatment is more effective than covering based water proofing. After water proofing consult a swimming pool expert. Proper drainage pipes should also be laid over the roof slab. Make sure you have installed a water proof covering with the thermoplastic or rubberized sheeting. Filter sheet is also necessary to drain off the moisture form the roof slab.
Swimming pool
3599
2630
direction for swimming pool
Last answer on 9/9/2010 1:46:11 PM. by sabina vanjani. Forum started by rajkumar
191984
2386
2293
3994
Roof leakage
2085
Is it good to buy a plot with swimming pool in the south? Is it good to buy a p
Last answer on 12/31/2020 2:51:34 AM. by sabina vanjani. Forum started by kamlesh bhavnani
2450
Last answer on 5/10/2012 7:34:26 PM. Forum started by MAHESH DHOMANE
I am planning to construct an house in Guntur and it is a 2 road bit and dimensi
Last answer on 3/17/2015 11:46:59 AM. by seema tyagi. Forum started by Narendra Kumar Saranam
8448
Roof Beam crack
5725
1822
4622
swimming pool construction
Last answer on 9/5/2021 4:54:13 AM. by S L Gupta (Civil Engg). Forum started by veby
404
flooring
Last answer on 12/18/2010 12:30:53 PM. by S L Gupta (Civil Engg). Forum started by ali
3510
Water leakage from the Swimming Pool
Last answer on 8/5/2020 12:58:17 AM. by S L Gupta (Civil Engg). Forum started by S. K. Agarwal
2436
Inground Swimming Pool
Last answer on 5/7/2010 9:31:08 PM. by naser. Forum started by ajit
2543
Complete Swimming Pool Construction Consulting & Execution
Last answer on 6/24/2021 12:35:33 AM. Forum started by Gunjan Utraja
7430
Last answer on 7/20/2020 11:36:14 PM. by Gunjan Utraja. Forum started by srinivas
108
48
17
23
21
20
21
21
20
20
22
18
21
20
22
15
Inground
Swimming
Swimming
Swimming Pool Maintenance
Maintenance of a pool is a major requirement that must not be taken lightly. Read this article to know tips on how to ..
Pool
Pool Heaters
You spend a lot of money to construct a swimming pool and on its other equipments. But if your pool is frequently too ..
Tips for Swimming Pool Lighting.
Water presents a challenging and rewarding medium for lighting. Swimming pools, fountains, waterfalls magically come t..
Swimming
Swimming Pool Filters
Swimming
Swimming Pool Covers
Pool covers become an important thing when the swimming season ends. As they reduce evaporation as well as protect you..
