Tue Apr 17, 2012 | Total posts : 2 |
| Topic: dear expert please give me lay out plan of north facing construction for 30*25ft
dear expert please give me lay out plan of north facing construction for 30*25ft with vastu compliant two bedroom cun lath bath kitchen drawing dinning stairs for up |
Wed Apr 18, 2012 | Post #1 | Gunjan Utraja
Join date: Dec 2007 | Post subject: Plans for 750 square feet plot.
We have launched a very cost effective architectural plan service that provide you readymade floor plans:
Please use the links given below that matches your requirements:
In order to purchase architectural plan through this service, please use the steps below. - You select a plan whose layout you like. Note down the plan code and purchase the plan.
- Once you purchase the plan, we will contact you and send you a questionnaire through which we will understand your requirements.
- We will assign a representative for your project and he/she will coordinate all your requirements.
- After discussions with you, we will adjust the plan according to your exact plot size and make as many changes as you like. Our prices are based on per square feet of built area and if after changes your built area increases by more than 10% then we will change for the increased area accordingly.
- If you also purchase guidance from Vastu expert then an independent vastu expert be assigned to your project and he/she will review your plan and suggest changes.
- Once the plan is finalized, we will give you dimensions as shown in the sample drawing and door window schedule.
- If you purchase more drawings then the same will be delivered to you according to the plan finalized by you.
- If you choose a 3-D option too, then the process works as below.
- After completion of the architectural plans, we will recommend and send to you a few pictures/3-D models of the homes. In those pictures, we will ask you to shortlist the items of the exterior elevations. You can also send us the pictures of homes that you like. Through the existing pictures, it will be easier for you to shortlist the material and shape of exterior elevation.
- Based on the architectural plans and your preferences, our 3-D designers will design the 3-D elevation for your home.
- If you purchase, 3-D elevation plan then you should also purchase the 2-D elevation plan as all dimensions and levels are provided in the 2-D elevation plans. Your contractor would use the details in the 2-D elevation plan to construct your home. The 3-D pictures are there for a reference so that both you and your contractor can visualize the same thing.
Thu Apr 19, 2012 | Post #2 | manish
Join date: Apr 2012 | Post subject: according vastu plan
expert please give me plan accrding vastu construction area may be 35*25 two bedroom withlathbath kitchen hall drawing room only up stairs also not to fabce of enterance
Questions (39) | |
5852 views | 1 answers | Last answer on 7/3/2020 9:39:24 PM. by ramu771964. Forum started by RAKESH DIXIT | 2019 views | 1 answers | Last answer on 1/21/2022 4:52:05 AM. by S L Gupta (Civil Engg). Forum started by lakshmi | 1080 views | 1 answers | Last answer on 7/4/2020 12:06:02 AM. by S L Gupta (Civil Engg). Forum started by rameshgupta |
| 1626 views | 1 answers | Last answer on 2/6/2017 12:12:43 PM. by S L Gupta (Civil Engg). Forum started by nandhini | 2142 views | 1 answers | Last answer on 4/17/2012 10:39:41 AM. by Gunjan Utraja. Forum started by mahesh | 1725 views | 1 answers | Last answer on 6/21/2016 12:58:07 AM. by Beenu Phogat. Forum started by PARAMJIT KUMAR CHUMBER | 8074 views | 2 answers | Last answer on 5/8/2017 12:41:49 PM. by Saurav anand. Forum started by Rav kumar | 11735 views | 1 answers | Last answer on 10/11/2020 7:24:29 AM. by Beenu Phogat. Forum started by cm singh | 2763 views | 1 answers | Last answer on 1/8/2022 8:19:06 AM. by seema tyagi. Forum started by PULIKESHI CHANNAVEERAGOUD | 5186 views | 2 answers | Last answer on 3/30/2012 7:14:11 AM. by sumanta roy. Forum started by Siddesh K | 12593 views | 1 answers | Last answer on 11/14/2016 11:10:55 AM. by Amit Hasija. Forum started by chakravrthi | 2457 views | 2 answers | Last answer on 9/1/2015 2:55:46 AM. by JAI PRAKASH. Forum started by Vijay | 1853 views | 1 answers | Last answer on 9/8/2021 6:08:07 AM. by S L Gupta (Civil Engg). Forum started by Gujjalaraja | 1677 views | 1 answers | Last answer on 4/4/2018 1:18:43 AM. by S L Gupta (Civil Engg). Forum started by Gujjalaraja | 2049 views | 2 answers | Last answer on 10/6/2015 8:20:03 PM. by JAI PRAKASH. Forum started by shilpa | 3573 views | 2 answers | Last answer on 3/29/2017 9:32:31 PM. by Saurav anand. Forum started by K M N GANESH | 3680 views | 3 answers | Last answer on 3/27/2015 10:34:41 AM. by himanshu. Forum started by shivendra | 2518 views | 2 answers | Last answer on 10/20/2016 6:00:32 PM. by JAI PRAKASH. Forum started by Naveen | 2128 views | 1 answers | Last answer on 5/12/2014 12:39:42 PM. by S L Gupta (Civil Engg). Forum started by nilesh agrawal | 102 views | 0 answers | Last answer on 1/11/2025 7:02:15 AM. Forum started by rupeshji | 46 views | 0 answers | Last answer on 1/11/2025 7:01:52 AM. Forum started by rupeshji | 16 views | 0 answers | Last answer on 1/11/2025 7:01:46 AM. Forum started by rupeshji | 22 views | 0 answers | Last answer on 1/11/2025 7:01:39 AM. Forum started by rupeshji | 21 views | 0 answers | Last answer on 1/11/2025 7:01:33 AM. Forum started by rupeshji | 20 views | 0 answers | Last answer on 1/11/2025 7:01:27 AM. Forum started by rupeshji | 0 views | 0 answers | Last answer on 1/11/2025 7:01:19 AM. Forum started by rupeshji | 19 views | 0 answers | Last answer on 1/11/2025 7:01:12 AM. Forum started by rupeshji | 21 views | 0 answers | Last answer on 1/11/2025 7:01:06 AM. Forum started by rupeshji | 21 views | 0 answers | Last answer on 1/11/2025 7:00:59 AM. Forum started by rupeshji | 16 views | 0 answers | Last answer on 1/11/2025 7:00:52 AM. Forum started by rupeshji | 20 views | 0 answers | Last answer on 1/11/2025 7:00:46 AM. Forum started by rupeshji | 19 views | 0 answers | Last answer on 1/11/2025 7:00:40 AM. Forum started by rupeshji | 21 views | 0 answers | Last answer on 1/11/2025 7:00:06 AM. Forum started by rupeshji | 18 views | 0 answers | Last answer on 1/11/2025 7:00:00 AM. Forum started by rupeshji | 21 views | 0 answers | Last answer on 1/11/2025 6:59:54 AM. Forum started by rupeshji | 19 views | 0 answers | Last answer on 1/11/2025 6:59:48 AM. Forum started by rupeshji | 22 views | 0 answers | Last answer on 1/11/2025 6:59:42 AM. Forum started by rupeshji | 15 views | 0 answers | Last answer on 1/11/2025 6:59:36 AM. Forum started by rupeshji | 19 views | 0 answers | Last answer on 1/11/2025 6:59:31 AM. Forum started by rupeshji |
Articles that might interest you! | | Home Construction Safety There are several home construction safety tips which can be applied during construction of the house. This article wi.. | | Linoleum Flooring Linoleum flooring is a popular choice when you are looking for style and ease at the budget. You can choose any color .. | | Tips for Laying RCC slab / roof RCC slab laying is one of major step in any type of construction so it is mandatory to know all the points related to .. | | Guideline for laying DPC Damp proof course or DPC is a major process in construction. There are several guideline meant for DPC which are desc.. | | Bathroom Plans and Layouts for 60 to 100 square feet Find 12 bathroom plans for the space of 60 to 100 square feet. Different layouts in different shaped bathroom but pra.. | | Bathroom Layouts and Plans for Spacious Bathrooms Find here 5 bathroom layouts and designs for extra large and multipurpose bathrooms. Plans show various luxurious fi.. | | Bathroom Plans and Layouts for Small Bathrooms Find 8 bathroom Plans and layouts for small bathrooms. Plans show the best possible arrangement of fixtures to make i.. | | Space Planning In Kitchen Kitchen is the heart of a home and each lady want her kitchen according to her desires. So the kitchen should be more .. | | EAST FACING PLOT A north-east facing plot is best for all type of constructions, whether a house or a business establishment. However, .. | | Mild Steel Bars in Cement Concrete Mild steel bars in reinforced concrete are one of the exceptional building materials. Reinforced concrete requires ver.. | | What are various types of glasses used in doors? Types of glasses used in doors-Clear window glass, Plate glass, Prism glass, Quartz glass, Processed glass....... | | What are advantages and disadvantages of folding doors? Advantages of folding doors- Easy to install,washable, durable, superior sound damping. Disadvantages-sensitive to har.. | | What are various designs available in wooden doors? Designs available in Wooden doors..... | | What is standard size of internal folding doors? Size, Thickness and Weight of Internal Folding Doors....... | | What affects the life of doors? What can we do to increase the life of the Wooden doors? Tips to increase the life of Wooden doors.... | | What is the standard size of frame for Plastic/PVC doors? Plastic Door frame size carrying one or two shutters...... | | What are various frames recommended for Plastic/PVC doors? Frames for Plastic Doors.......... | | Which place is appropriate for sliding door? Appropriate places for sliding doors-Bathrooms, Backyards, Commercial structures........... | | What are various frames recommended for glass doors? Frames for Glass Doors-Wooden frames, Steel frames, Aluminium frames...... | | Which place is appropriate for folding doors? Appropriate places for folding doors-Homes, Offices, Guest rooms, gives attaractive and stylish look........ | | What are the various accessories recommended for folding doors? Accessories for folding doors- Door Handles, Door Fasteners,Door Viewers....... | | What affects the life of doors? What can we do to increase the life of the Plastic/PVC doors? Tips to increase the life of Plastic doors.... |
