Tue Jun 21, 2016Total posts : 2
mani
mani
Topic: How to calculate lime concrete quantity in weathering course
Tue Jun 21, 2016Post  #1
Dear Mani
         Calculate the quantity of weathering coarse as length x width x thickness= ..cft( quantity)
 1 cft = lime = .20 cft
Coarse sand= .4 cft
Brick aggregate= .8 cft.
Fri Feb 18, 2022Post  #2
SusanBones
SusanBones
Post subject: Essays on the profession
The ability to correctly calculate the composition of the building mixture confirms that you need to get a quality education.
6327
terrace flooring
Last answer on 7/3/2020 10:25:00 PM. by JAI PRAKASH. Forum started by Radhika
5028
Weathering course
Last answer on 7/25/2014 9:42:13 PM. by JAI PRAKASH. Forum started by Radhika
2703
1767
31876
which one best for terrace weathering course or roof tiles?
Last answer on 9/15/2017 2:51:27 AM. by s.anbukuppusamy. Forum started by Arun
13015
HOW TO CALCULATE THE REQUIRED QUANTITY OF BRICKS, CEMENT AND STEEL
Last answer on 7/31/2011 12:54:31 PM. by S L Gupta (Civil Engg). Forum started by sanjay
3019
2407
Last answer on 6/24/2013 9:59:46 PM. Forum started by chethan
2692
shuttering calucation
Last answer on 4/8/2014 1:21:34 PM. by S L Gupta (Civil Engg). Forum started by shaik khaja nayab rasool
1798
weather it suitable for east facing plot.
Last answer on 1/19/2015 1:34:29 PM. by VastuMoorthy. Forum started by L.C.Sharma
1803
HiI want to calculate Life Cycle Cost of normal ordinary concrete roof and brick
Last answer on 5/12/2015 2:38:18 AM. by JAI PRAKASH. Forum started by Saikat Sahu
2704
Tips for Dry Distemper Paint
Last answer on 12/8/2009 2:37:57 PM. by Prem Bhatia. Forum started by RIZVI
3213
Nubian Vaults
Last answer on 12/31/2020 1:57:43 AM. by H S Rathi. Forum started by Boovarahan S
3027
Lime Tree can plant inside the Cam-pond Wall?is yes, which place is better to pl
Last answer on 7/3/2020 9:22:04 PM. by S L Gupta (Civil Engg). Forum started by Ramana
4224
1862
Water dripping and Damp patches after laying sunban tiles(igloo tiles) in terrace
Last answer on 8/5/2015 4:24:08 AM. by JAI PRAKASH. Forum started by Radhika
2333
how to calculate brick estimation
Last answer on 1/22/2022 7:01:42 AM. by bhuvaneshwaran bn. Forum started by mohammed nayeemuddin
1692
How to calculate in which pads does our design of house main door comes
Last answer on 9/16/2016 7:15:35 AM. by Suprabha. Forum started by Suprabha
103
47
22
21
20
21
21
20
20
21
18
21
22
15
Guideline for laying DPC
Cupola accessories
Detailed information about cupola accessories
Concrete Decor
Concrete Mix Ratio
Which type of Damp Proof Course (DPC) is recommended for protection from cracks ?
The best DPC is of plastic membrane placed across the whole width of the wall to its full length
Damp
Damp Proofing
