Home -> Forums -> Construction -> Green Building -> Low cost roofing solution over a slanting slab for internal cooling
Thu Nov 28, 2013Total posts : 2
Girish
Girish
Topic: Low cost roofing solution over a slanting slab for internal cooling
Could anybody suggest a solution ....??? I have bungalow in Goa and it has a sloping roof slab[inverted "V" shape] which is directly exposed to hot sun. Due to this inside rooms don't remain cool even in a moderate winter season. To overcome this I am planning to use additional  roofing of some material which could be cost effective. Kindly suggest the remedy...
Fri Nov 29, 2013Post  #1
Dear Girish
          Thermal insulation is a method to reduce the transfer of heat from outside to inside. To make house heat proof, thermal insulation is a good choice. An insulated home is more comfortable as the temperature remains consistent over weather changes. It makes the house comfortable and keeps the temperature of   house cool in summers and warm in winters. It is very useful to keep the temperature of the house independent from outside temperature.See the link below for more information about thermal insulation.
http://www.gharexpert.com/articles/Finishing-1607/Thermal-Insulation-Home_0.aspx
Sun Dec 01, 2013Post  #2
Girish
Girish
Post subject: Thanks Shri. Gupta Sir....but I have an idea in ...
The idea is to fix high quality marine ply of say 1 " thickness over the "inverted V" slab and thereon screw  the normal TATA roofing sheet in GI.. along with the GI ridge. What will happen is , as the wood is bad conductor of heat, it will act as the insulation between the slab and the GI sheets. Sir, kindly go through this idea and let me know  your opinion. thanks.....
Green Building-Construction Questions (38)
1911
2818
hai my house is constructed 7 years ago, now the roof slab is leaking year by y
Last answer on 7/3/2020 11:41:25 PM. by S L Gupta (Civil Engg). Forum started by vidya
roofing on open terrace
1806
Tiles
Last answer on 1/11/2022 5:32:54 AM. by Ben. Forum started by Yuwraj
191984
9945
3978
Low cost viila design up to plot area 200 sq.yard only
Last answer on 10/18/2016 5:13:31 PM. by Vijaya. Forum started by Syed Zakir Ali
4090
3755
How to cast sloped/slanted roof, as our architect described inablity to use vibr
Last answer on 3/5/2013 12:11:16 PM. by S L Gupta (Civil Engg). Forum started by mrityunjay singh
4964
1933
3786
1711
Cool proof tiles
Last answer on 5/19/2016 12:31:25 PM. by S L Gupta (Civil Engg). Forum started by Rajendran
2105
3994
Roof leakage
4830
2891
2285
wall
Last answer on 12/12/2012 12:27:36 PM. by S L Gupta (Civil Engg). Forum started by saif
1844
roof farming
Last answer on 2/25/2022 4:26:25 AM. by S L Gupta (Civil Engg). Forum started by raj
3287
Last answer on 1/24/2022 9:52:50 PM. by S L Gupta (Civil Engg). Forum started by Akash Sharma
3193
Architect to Build Green Modern Home in Bangalore
Last answer on 11/21/2021 1:07:48 PM. by fabions. Forum started by rahulsharma
2944
Help with a documentary about sustainability
Last answer on 10/5/2021 8:27:02 AM. by S L Gupta (Civil Engg). Forum started by Chibi Moku
3038
hpl panels for exterior
Last answer on 8/26/2021 8:40:25 AM. by HardissonHard. Forum started by kamal
2892
estimation
1810
Last answer on 7/4/2020 2:05:29 AM. Forum started by Alisson Chan
2154
Marriage Palace & School Auditorium
Last answer on 7/3/2020 11:27:36 PM. by S L Gupta (Civil Engg). Forum started by Marinedeejay
1775
House plan
Last answer on 7/3/2020 11:15:18 PM. by JAI PRAKASH. Forum started by udaykumar mugali
3521
Last answer on 7/3/2020 9:53:22 PM. by seema tyagi. Forum started by Modern Homes
1327
Is there any transparent sheets available for tress work on roof so as to cultivate on Terrance?
Last answer on 2/21/2017 12:33:33 PM. by S L Gupta (Civil Engg). Forum started by vinu
1688
Concrete Roof Insulation
Last answer on 6/25/2016 11:19:30 AM. by S L Gupta (Civil Engg). Forum started by Omar Chaudhry
1743
Solar energy integrated houses
Last answer on 7/6/2015 12:24:02 AM. by JAI PRAKASH. Forum started by Kumar
4209
Low cost housing option
Last answer on 8/11/2014 9:23:57 PM. by JAI PRAKASH. Forum started by Dinesh Sharma
1846
Cost of construction - Less expensive?
Last answer on 10/16/2013 12:53:12 PM. by S L Gupta (Civil Engg). Forum started by Prasad
2666
cost of construction of type G + 2
Last answer on 8/26/2012 4:08:55 PM. Forum started by santhosh
2719
Chemtreat India
Last answer on 9/8/2011 3:05:20 PM. Forum started by Chemtreat India
2297
interiors
Last answer on 7/15/2011 4:05:38 PM. Forum started by keerthi
Green
Cooper
