Home -> Forums -> Construction -> Cement Concrete Flooring -> Material and cost of Tezzarro flooring
Thu Jul 19, 2012Total posts : 1
Raj
Raj
Topic: Material and cost of Tezzarro flooring
Please let me know material for tezzarro flooring. I need to do this on 2500sqfeet area in my house.
Fri Jul 20, 2012Post  #1
Dear Raj
          The floor consists of an under layer of cement concrete in ratio of 1:2:4(1 part of cement: 2 parts of coarse sand: 4 parts of graded stone aggregate 12.5 mm nominal size). Its thickness depends on size of marble chips used.
              Cement concrete mixture should be used for under layer. The panels should be of uniform size. In exposed situations, length of any side of the panel should not be more than 1.25m.
Fixing Strips
4 mm thick glass strips, 1.6 mm thick aluminum strips or 2mm thick PVC strips should be fixed with their top at proper level to get required slope.
Top Layer
The mixture for topping should consist of cement with or without pigments, marble powder, marble chips and water. The cement and marble powder should be mixed in ratio of 3:1 by weight.
For 2500 sft floor when you are laying top layer 9mm thickof marble chips and cement in 4;7 ratio.
Cement =89 bags
Bazri =250cft
Coarse sand= 125 cft
Marble chips=35 qtl
Marble powder= 10cft
The quantity decrease if you want to lay top layer 6mm thick and increase in case 12 mm top layer. For terrazo floor see the link below.
http://www.gharexpert.com/articles/Flooring-1495/Terrazzo-flooring-Mosaic-or-Marble-chip-flooring-_0.aspx
Cement Concrete Flooring-Construction Questions (27)
3827
2218
1857
I want to construt 1200X900x50 mm chamber cover.what will be cost (material and
Last answer on 3/2/2015 11:59:21 AM. by S L Gupta (Civil Engg). Forum started by sachin kale
2891
7256
2 lakh litre water tank
2010
HOW MUCH COST WILL BE 3 BHK IN 1500 SQUARE FEET, PLEASE GIVE DETAILWISE MATERIAL
Last answer on 12/9/2015 11:40:05 AM. by S L Gupta (Civil Engg). Forum started by manoj
3861
comments required
Last answer on 11/18/2021 7:51:18 AM. by Gunjan Utraja. Forum started by gangula
2832
building a house
1700
Last answer on 10/7/2014 11:37:58 AM. by S L Gupta (Civil Engg). Forum started by SANJAY DUSANE
2124
wich material using in flooring
Last answer on 10/21/2010 11:27:03 PM. by Gunjan Utraja. Forum started by Ranjit Shirke
2827
What is the cost of Home Lift capacity for four persons for four floors building
Last answer on 7/16/2014 7:56:03 PM. by JAI PRAKASH. Forum started by A Prasad
2091
how much will it cost for 2 floors superstructure,
Last answer on 7/19/2010 8:31:02 PM. by harbans singh sekhon. Forum started by N A.LAWAY
2671
I want to know the cost of this flooring per square feet
Last answer on 8/27/2013 12:29:33 PM. by S L Gupta (Civil Engg). Forum started by b.jaganathan
3161
Last answer on 7/3/2020 9:54:13 PM. by S L Gupta (Civil Engg). Forum started by padmaraju
2711
can any one tell me abt bamboo flooring .their cost and durability
Last answer on 1/6/2022 2:56:27 AM. by Swati Satija. Forum started by padmaraju
6483
1804
Tiles
Last answer on 1/11/2022 5:32:54 AM. by Ben. Forum started by Yuwraj
1500
2583
2347
Roof flooring
1412
3638
Per Sq:ft rate for flooring
1414
Colored concrete floor
Last answer on 10/22/2016 11:14:47 AM. by S L Gupta (Civil Engg). Forum started by Pooja
1538
concrete floors
2012
1650
floor construction
2141
Floor thickness
Specification of Brick
Fire
Which types of finishing materials are recommended for glass windows?
1.Glass Former: It is the primary material. 2.Flux: It lowers the melting temperature as well as viscosity. ..
Raw Materials and Scaffolding for ‘Plastering’
Raw material and scaffolding are backbone of 'Plastering' and provide necessary support in construction.
