Home -> Forums -> Construction -> Coarse Aggregate -> Purchasing Guidelines for Coarse Aggregate
Mon Jul 11, 2011Total posts : 1
KALPANA
KALPANA
Topic: Purchasing Guidelines for Coarse Aggregate
I need conststruction material rates arounding chennai
The comment above talks about the article   "Purchasing Guidelines for Coarse Aggregate "
Wed Jul 20, 2011Post  #1
 Dear Kalpna
The course aggrigate is the most important part of the cement concrete and the strength of concrete depends on the quality of coarse aggrigate.For purchasing guideline you should take help from the artcle link given below.
http://www.gharexpert.com/articles/Coarse-Aggregate-1502/Purchasing-Guidelines-Coarse-Aggregate_0.aspx
Coarse Aggregate-Construction Questions (19)
3515
1627
Specification of Coarse Aggregate
Last answer on 1/23/2013 1:02:12 PM. by S L Gupta (Civil Engg). Forum started by S P Singh
2734
2028
coarse aggregate
1573
Last answer on 6/7/2017 12:20:58 PM. by S L Gupta (Civil Engg). Forum started by Sandeep Vidwans
2265
about construction
2555
Last answer on 6/19/2009 8:57:08 PM. by S.Krishnan. Forum started by anil
3433
Purchasing Guidelines for Marble and Granite Stone
Last answer on 12/31/2020 2:29:42 AM. by Sonu chaudhary. Forum started by kavitha
2346
Last answer on 9/19/2012 1:30:40 PM. by r s rawat. Forum started by mujahedsabb
2277
Last answer on 5/26/2012 8:18:55 AM. by S L Gupta (Civil Engg). Forum started by hafiz
1687
3898
2347
Roof flooring
1942
1799
from where can i purchase ?
Last answer on 1/12/2022 2:36:45 AM. Forum started by K K Awasthi
2673
I am purchasing a land 42x62 i want to make my home please give us idia
Last answer on 3/19/2012 3:31:22 PM. by Gunjan Utraja. Forum started by DILIP
2008
where we purchase railling material
Last answer on 10/4/2012 12:53:15 AM. by kamal. Forum started by Rajesh
3574
Last answer on 3/29/2017 9:32:31 PM. by Saurav anand. Forum started by K M N GANESH
2163
Anyone know where the pendants can be purchased?
Last answer on 2/9/2022 1:49:41 AM. by jyoti. Forum started by jp medley
Density of Coarse Aggregate
Coarse Aggregate consists of crushed, uncrushed or broken stones. Check the grading of sand for proper sizes.
What is aggregate
There are mainly two types of aggregate:Fine aggregate and coarse aggregate. Let us know more about aggeregate in foll..
Buying tips for Brick Blast
Buying
Buying tips for Cement
Aggregates of concrete and their density
In cement concrete aggregates occupy 75-80 percent volume of concrete, so you can say Aggregate is a major resource fo..
