What is best method to clean GI Door frames after cement plaster is over. If har
Fri Apr 05, 2019Total posts : 1
Surinder Singh
Surinder Singh
Topic: What is best method to clean GI Door frames after cement plaster is over. If har
What is best method to clean GI Door frames after cement plaster is over. If harsh sandpaper is used, it will rear primer and even zinc coating thus ending protection. using metal object to scrap off cement will also hurt primer and zinc layers. Tried cleaning with regmar number 600, seems to give desired results. What would be best way?
Fri Apr 05, 2019Post  #1
Surinder Singh
Surinder Singh
Post subject: attaching picture
attaching picture of GI door frame with cement spread.
Attachments: doorFrameGIdirtycement.png Fri Apr 05, 2019,&n
SIR, I AM CONSRUTING MY HOUSE IN PATIALA AND CONFUSE THAT WHICH PIPE GI , PVC ,U
Last answer on 1/18/2012 8:33:27 AM. by ravi at Dalmia. Forum started by HARISH SAHNI
4246
Selection of cement ..
2545
5046
1986
3238
5245
2347
Last answer on 11/19/2013 1:31:03 PM. by Amit Hasija. Forum started by Toby Tyler
2869
Can u pls send me price for upvc door and door frame.Thomas
Last answer on 7/4/2020 3:07:03 AM. Forum started by Thomas Rodrigues
2229
how to clean sunmica doors
Last answer on 7/15/2021 12:45:52 AM. by HardissonHard. Forum started by Anu
7025
2707
cement plastering
4005
2220
about home
Last answer on 12/14/2013 12:16:30 PM. by S L Gupta (Civil Engg). Forum started by madhu
2118
joinery work
Last answer on 4/26/2011 9:58:00 PM. Forum started by suresh
2549
i want modren designs of main door frames.please sent the images to prashanthkum
Last answer on 11/18/2013 4:12:52 PM. by S L Gupta (Civil Engg). Forum started by kiranmai.a
2697
3287
Door Frames
Last answer on 10/22/2010 12:50:15 PM. by Mohammed Moin. Forum started by Mohammed Moin
5279
112
48
17
24
21
20
21
21
20
20
22
21
20
22
15
How to clean plaster ceiling?
Bathroom Cleaning Tips
Carpet
Carpet Cleaning Tips
Kitchen Cleaning Tips
Checklist for Cement Plaster
Gypsum
Specification of ‘Plastering’
Door
Door and Window Frames
