Home -> Forums -> Construction -> Cement Concrete Flooring -> Floor thickness
Floor thickness
Thu Sep 04, 2014Total posts : 2
ravi pachipala
ravi pachipala
Topic: Floor thickness
Hi I would appreciate what is the normal thickness for the concrete fllor for Tiles. my tiles person is telling we need to got for 3 inches thickness of flooring including tile thickness. my concern is if the slab can take the load of 3 inches weight of the floor thickness.
Thu Sep 04, 2014Post  #1
3-4 inches is ok
Fri Sep 05, 2014Post  #2
Dear Ravi
        Slab can take load of 3'' flooring.
Cement Concrete Flooring-Construction Questions (27)
2347
Roof flooring
2598
what is the wall thickness for a 9000 sqft building
Last answer on 4/3/2021 12:46:58 AM. by S L Gupta (Civil Engg). Forum started by shankar
2733
8358
2894
Steel calculation
7311
2619
roof thickness
Last answer on 2/26/2022 9:17:15 AM. by S L Gupta (Civil Engg). Forum started by gautam kumar
2838
6585
2880
1911
What are various accessories recommended for wooden doors?
Last answer on 2/21/2014 11:53:38 AM. by S L Gupta (Civil Engg). Forum started by satish
3292
3993
Roof leakage
3857
Roof Beam
5244
2243
2135
Wall Thickness
2701
Last answer on 7/2/2021 3:17:17 PM. by B Thakar. Forum started by minhaj sk
4165
2347
Roof flooring
1412
3638
Per Sq:ft rate for flooring
1414
Colored concrete floor
Last answer on 10/22/2016 11:14:47 AM. by S L Gupta (Civil Engg). Forum started by Pooja
1538
concrete floors
2012
1650
floor construction
2485
Material and cost of Tezzarro flooring
Last answer on 7/20/2012 11:33:53 AM. by S L Gupta (Civil Engg). Forum started by Raj
What is the thickness of PVC pipes and diameter for drainage ?
Thickness of PVC Pipes and various diameters for drainage are .........
What is the standard thickness of glass for glass windows?
The standard thickness of glass
What is the recommended thickness of the under and the top layer of terrazzo tile flooring?
The under layer is made up of cement concrete in 1:2:4 Ratio (1-Cement,2 corse sand, 4 stone aggtregate ) and is aroun..
What is Glass Window
A transparent opening in a wall is called window. Usually windows are covered by transparent or glazed material like g..
Centering
Terrazzo
