Hello,can you pls advice on following.1)is it ok to buy BWR grade local flush pi
Tue Feb 07, 2017Total posts : 1
Manish Chugh
Manish Chugh
Topic: Hello,can you pls advice on following.1)is it ok to buy BWR grade local flush pi
Hello,can you pls advice on following.1)is it ok to buy BWR grade local flush pine door or we should buy BWP grade. we need to use doors in lobby ?2)we will paste sunmica on flush door. Is it necessary to install margin of 2mm on the edges of the flush door. some people says it increases the life of door and prevent the sunmica from peeling off ? further any issues by installing marigin like door lock issue etc ?
Tue Feb 07, 2017Post  #1
Dear Chug,
        Both the grade of good brand is good use of sun mica increase the life.
Installation/ fixing The Sun mica / laminates are fixed on the supporting base of ply wood, block board, particle board etc by adhesives. The supporting base should be sanded and free from dust, wax, grease etc. After applying proper adhesive the sheet of laminate is spread and hand rolled from centre to edge and remove all air bubbles.  To ensure adequate bond, sufficient pressure should be applied over the entire area of assembly.
flush toilet
1266
Hello,all local brands dealers say have printed 32mm for flush doors but dealers
Last answer on 2/8/2017 2:42:03 PM. by S L Gupta (Civil Engg). Forum started by Manish Chugh
1840
i am building my house.should i go for tata/sail or local ones like kamdhenu/amb
Last answer on 4/2/2016 1:13:17 PM. by Praveen. Forum started by prasad K
28712
Good Plywood for woodwork
Last answer on 10/26/2016 8:39:11 PM. by JAI PRAKASH. Forum started by raghuam
1920
Flush Door
Last answer on 1/9/2015 12:07:10 AM. by JAI PRAKASH. Forum started by paresh
2103
Flush Door
Last answer on 7/3/2020 10:16:38 PM. by JAI PRAKASH. Forum started by paresh
2071
Hello,Please advice remedy for Fire place in North East.Thanks
Last answer on 5/19/2016 8:02:25 PM. by mukesh. Forum started by savithri
1705
Hello to all, I am looking out for effective interior designing suport at Vad
Last answer on 10/9/2020 2:20:58 AM. by JAI PRAKASH. Forum started by Sunil
7266
I'm fond of hunting, so the technique that I buy is quite specific, however I lo
Last answer on 1/5/2022 12:34:54 AM. by HardissonHard. Forum started by RadyGoldy
3461
Type of Cement
3253
3085
Steel
2710
302 vs 304 grade steel for ralling
Last answer on 3/20/2015 9:55:35 PM. by JAI PRAKASH. Forum started by paresh
2520
interiors for bedroom
Last answer on 7/19/2016 2:49:37 PM. by AR. HIMANSHU PHOGAT. Forum started by sowmya
2322
pls. advice to me about interior decoration
Last answer on 2/12/2015 8:58:48 PM. by JAI PRAKASH. Forum started by Munish Dutta
2743
2935
Last answer on 4/11/2017 11:10:57 AM. by S L Gupta (Civil Engg). Forum started by vinu
2332
cement
Last answer on 8/25/2012 12:33:40 AM. by Ar. Manoj Ralen. Forum started by abhijeet joshi
1654
I am planning to buy a flat. It's main door opens to South. Is it ok to buy this
Last answer on 7/24/2011 1:20:56 AM. by sabina vanjani. Forum started by Nikhil Alekar
108
48
17
23
21
20
21
21
20
20
22
18
21
20
22
15
Buying
Buying Guide for Garage Door
Buying tips for Bricks
Buying tips for Brick Blast
Buying
Buying tips for Cement
Mortise
Mortise Locks
Mortise locks become very popular due to high security, easy to maintain and give aesthetic view. The article gives us..
Mortise
Mortise Locks
Why you should buy uPVC Windows by WindowMagic at GharExpert.com
Maximum Wind Resistance :Window magic Kommerling uPVC window and door systems are ideal for being installed in buildings
