HiI want to calculate Life Cycle Cost of normal ordinary concrete roof and brick
Wed Apr 29, 2015Total posts : 2
Saikat Sahu
Saikat Sahu
Topic: HiI want to calculate Life Cycle Cost of normal ordinary concrete roof and brick
HiI want to calculate Life Cycle Cost of normal ordinary concrete roof and brick wall with plaster. So it will be great help if you kindly provide- Set up or initial cost- Repair and Maintenance Cost- Single Expenditureand- Salvage Valueof both of them.
Mon May 04, 2015Post  #1
Your Query is not clear.
Tue May 12, 2015Post  #2
What do you want?
type of brick
2039
20195
5233
191984
9243
1082
3052
2333
how to calculate brick estimation
Last answer on 1/22/2022 7:01:42 AM. by bhuvaneshwaran bn. Forum started by mohammed nayeemuddin
35258
3474
2166
2548
2672
Chain type staircase
Last answer on 10/23/2021 8:23:18 AM. by S L Gupta (Civil Engg). Forum started by Praveen
3454
3477
Cost of Brick Work
Last answer on 6/4/2014 3:43:02 PM. by S L Gupta (Civil Engg). Forum started by Subhajit Kundu
2438
roof concrete
2433
2180
109
48
17
23
21
20
21
21
20
20
22
18
21
20
22
15
The Five Elements In Feng Shui
The Chinese recognise 5 elements which arise out of the interplay of yin and yang. Ideally there should be a balance o..
Concrete Mix Ratio
White
White Cement
You can boost up architectural beauty of your home using white cement since the strength of building and its component..
Cooper
