I want tips of procedure of water primer on wall putty. When the water primer sh
Thu Jul 08, 2010Total posts : 1
Arup Ray
Arup Ray
Topic: I want tips of procedure of water primer on wall putty. When the water primer sh
I want tips of procedure of water primer on wall putty. When the water primer should paint on wall putty ?
Thu Jul 08, 2010Post  #1
Dear Arup Ray
                Tips;-
• Dry out the new wall surface.
• Old surface should be free from loose, powdery particles by scraping.
• Water based cement primer after thinning with water, apply on the surface after filling the minor cracks and defects.
• Apply wall putty after the first coat of primer.
• Rub the surface with emery paper to smoothen the surface.
• Apply the final coat of primer on putty surface.
Wall Putty ,primer and paint
2159
acrylic vs primer
Last answer on 1/21/2015 11:35:40 AM. by S L Gupta (Civil Engg). Forum started by paresh
3018
1835
wall primer
Last answer on 1/10/2016 9:04:01 PM. by JAI PRAKASH. Forum started by Anu
2376
estimation
9562
Wall Putty and primer
2952
Plaster
3095
Painting
2775
1710
2298
chowkets
Last answer on 9/16/2021 10:06:13 PM. by JAI PRAKASH. Forum started by ARVIND GOYAL
3984
water proofing of water tank
2034
How much White Cement will be required as Primer Coat on Fresh Raw Wall for appr
Last answer on 6/24/2013 3:01:38 PM. by S L Gupta (Civil Engg). Forum started by JAYANT VERMA
3105
What type primer and paint should be used for concrete window and door frames?
Last answer on 6/5/2017 12:48:40 PM. by S L Gupta (Civil Engg). Forum started by vinu
3392
1913
wall putty
Last answer on 7/3/2020 11:12:22 PM. by JAI PRAKASH. Forum started by ARVIND GOYAL
3301
Wall Putty on exterior wall
8930
2256
116
49
18
25
21
21
20
21
22
17
21
21
22
20
22
21
22
20
Water for Construction
60
60 Tips to Save Water
Painting
Vastu for Water Tank
Tips for Swimming Pool Lighting.
Water presents a challenging and rewarding medium for lighting. Swimming pools, fountains, waterfalls magically come t..
What is the raw material recommended for painting of metal surface?
Red oxide zinc chromate primer shall be used for iron and steel work including galvanized steel.Zinc chromate primer s..
Rain
Rain Water Harvesting
Preventive
