Home -> Forums -> Vastu -> Bathroom -> Vaasthu for external staircase
Wed Jan 21, 2015Total posts : 10
SAROJINI
SAROJINI
Topic: Vaasthu for external staircase
Mine  is a east facing plot.we want to construct external staircase. Only space available is in north side. I have my sump in north east corner. Now we are planning to construct the staircase in north side touching north west, not completely in north west. Is it okay as per vaasthu? Length is 48 ft E-W.Planning to start the staircase after 14 ft from NE corner. Advice..Thanks.
Wed Jan 21, 2015Post  #1
Post subject: vastu for stairs
             yes North-East side is good for sump. and North - West is also acceptable for staircase.
But id still you have any doubt please consult with a vastu expert.
Thanks.
Wed Jan 21, 2015Post  #2
SAROJINI
SAROJINI
Thanks seema. But my question is , is it okay to be in north? Neither NE nor NW.
Wed Jan 21, 2015Post  #3
Hi Sarojini,
  For East face house you can go for East of South-East staircase[as a second alternate].
 As per vastu staircase should not be at NE and also North [because it is considered as  weight / covered structure].
 But you can provide staircase at North of North-West.
 In the given condition[width] it is part of North.
If possible try to adjust[dimension / design of Stairs] to words NorthWest.
(Vastu Expert)
Thu Jan 22, 2015Post  #4
SAROJINI
SAROJINI
Thanks Nageshwar. In north west corner we are having storage/ utility.Also can u tell me ,if the length is 48 feet how much feet is allocated in each direction, ie NE, N and NW. Thanks.
Fri Jan 23, 2015Post  #5
NW- 11 Ft
N    - 26 Ft
NE - 11 Ft
Fri Jan 23, 2015Post  #6
SAROJINI
SAROJINI
Thanks a lot.
Thu Feb 05, 2015Post  #7
Pavan
Pavan
Post subject: Vastu for external stair case
Hello Sarojini.
If I understand this discussion correctly ,Here you are discussing about the entry to secondary Vastu (Bhavana), that is your House/Banglow. It would be of great help if you can share the plan of the house and your proposal about the stair case. Apart from Vastu there has to be a practical approach for this stair case too.
For entry into a vastu (Land) there are different parameters and for entry into Bhavana (House) there are different parameters. Hence the plan would definitely help.
Regards.
Pavan Matkar
Wastu Wimarsh
Wed Feb 11, 2015Post  #8
SAROJINI
SAROJINI
plan attached of ground floor. check the 3rd page of attachment for plan. thanks
Attachments: gf.pdf Wed Feb 11, 2015,&n
Wed Feb 11, 2015Post  #9
SAROJINI
SAROJINI
proposed staircase also shown..stove placement in kitchen also shown..thanks. Northwest next to kitchen is storage room.
Wed Feb 11, 2015Post  #10
All rooms internally should be maintained 90 degrees at corners[According to vastu].
Bathroom-Vastu Questions (38)
2033
for south facing site external staircase should be in whitch direction
Last answer on 12/12/2010 1:15:56 AM. Forum started by KALAIVANI
1963
best material for external grills ,staircase
Last answer on 8/29/2014 2:08:35 AM. by JAI PRAKASH. Forum started by ADINATH
11310
15*63 plot south facing how to use vaasthu plane
Last answer on 9/17/2021 12:26:30 AM. by S L Gupta (Civil Engg). Forum started by krishnamoorthy
10806
25*50 east facing plot, i want plan with vaasthu
Last answer on 11/28/2016 1:27:42 PM. by Beenu Phogat. Forum started by Kranthikumar
1707
In East facing home the external stairs for enterance on North East is good or n
Last answer on 11/16/2017 10:34:49 PM. by S L Gupta (Civil Engg). Forum started by Deepshikha Jaiswal
1390
I want external stair design
Last answer on 4/2/2016 11:25:11 AM. by S L Gupta (Civil Engg). Forum started by pushpak
2011
best designs for external stair cases
Last answer on 9/20/2021 12:33:21 PM. by JAI PRAKASH. Forum started by rambo fernandes
2374
estimation
3254
I want to paint my house plz suggest the colour for internal rooms & external
Last answer on 2/15/2012 10:39:54 PM. by skycrane. Forum started by vago suzare
1626
Last answer on 3/8/2017 11:11:29 AM. by S L Gupta (Civil Engg). Forum started by kirankumar
2256
2355
remedies for anticlockwise staircase in Brahmasthana
Last answer on 12/30/2011 7:42:54 PM. Forum started by vibin
2290
Last answer on 8/25/2011 4:35:06 PM. by Naveen. Forum started by supraja
15694
2435
my staircase starts from NE corner
Last answer on 9/11/2020 10:43:05 PM. by M Jindal. Forum started by pankaj
2870
Last answer on 12/9/2010 11:06:35 PM. by S L Gupta (Civil Engg). Forum started by kapil
2889
Position of staircase as per vastu
Last answer on 2/3/2011 10:41:29 AM. by nith_piyush. Forum started by Bhovotosh Deb
2665
4915
what is remedy for staircase in ne direction.
Last answer on 6/27/2019 11:51:27 PM. by Pavan. Forum started by asgodse
2657
Bedroom in the North
Last answer on 11/7/2021 10:00:29 PM. by Jennifer Ortega. Forum started by Diana
2357
Sleeping in Master bedroom
Last answer on 9/29/2021 6:58:47 AM. by Amit Hasija. Forum started by shyam
2990
Location of Septic tank
Last answer on 6/4/2021 2:20:12 AM. by shadow. Forum started by PR Jawahar
2685
vastu advice
Last answer on 3/5/2021 2:46:08 PM. by smithjames758. Forum started by pallubc2
8465
Position of Bathroom & Toilet
Last answer on 12/27/2020 8:52:28 PM. by HRJ. Forum started by Govarthan
1916
Last answer on 12/25/2020 3:36:39 PM. by S L Gupta (Civil Engg). Forum started by Dheeraj Grover
2769
Last answer on 7/3/2020 11:37:04 PM. Forum started by sumathi
2046
bathroom toilet in the north
Last answer on 7/3/2020 10:12:12 PM. by ADINATH. Forum started by ADINATH
1335
Remadies of vastudosh about toilet and bathroom
Last answer on 1/31/2017 11:53:43 AM. by S L Gupta (Civil Engg). Forum started by Sandeep singh yadav
2637
Vastu of the attached flat
1475
Secondary Toilet in South West
Last answer on 10/13/2016 11:22:14 AM. by S L Gupta (Civil Engg). Forum started by Vinay
2196
we have 900 sq ft space want to build,kindly suggest for some map....vastu accor
Last answer on 6/23/2015 3:22:38 PM. by seema tyagi. Forum started by Raj
2545
Bathroom vastu
Last answer on 1/16/2015 1:03:43 AM. by JAI PRAKASH. Forum started by Sai Pavana
1825
outside north side bathroom adjacent to buidling wall
Last answer on 1/15/2015 10:46:27 PM. by JAI PRAKASH. Forum started by karuna kumar
2197
bathroom plant
Last answer on 10/13/2014 3:32:30 PM. by sam. Forum started by sam
1919
Vastu Advice
Last answer on 7/27/2014 9:40:43 PM. by Purvi Panchal. Forum started by Esha
1991
vastu suggestion
Last answer on 4/23/2014 3:53:20 PM. by seema tyagi. Forum started by abhay srivastava
2218
about home
Last answer on 12/14/2013 12:16:30 PM. by S L Gupta (Civil Engg). Forum started by madhu
2694
Vastu for North East Bathroom & South East Kitchen opposite each other
Last answer on 5/19/2013 7:48:29 PM. by Ravi. Forum started by Riya Bansal
Staircase
Staircase railings
Hardwood
Hardwood door
Hardwood
Hardwood window
Stairs
Stairs Design
How to Design Stairs?
