What are the special characters of different kind of bricks.Size of a cement bri
Sun Jan 26, 2014Total posts : 1
Dilip
Dilip
Topic: What are the special characters of different kind of bricks.Size of a cement bri
What are the special characters of different kind of bricks.Size of a cement brick as compared to cement one and cost analysis. It is said that the cement bricks retain day heat and in the evening/night romms become hot. Expert comments on this will be highly appreciated
Tue Jan 28, 2014Post  #1
Dear Dalip
     There are cement blocks which are costly as compared to bricks. Cement blocks are good conductor in comparison of kiln earth bricks. There is difficulty of bond, joints and fixing fittings in case of cement blocks.
    There are three types of bricks
  • First Class Bricks
  • Second Class Bricks
  • Third Class Bricks
  Specification of First Class Bricks
  • Made of good earth which is free from saline deposits and are sand molded.
  • Burnt thoroughly without being vitrified and have deep red, cherry and copper color.
  • Regular and uniform in shape and size with sharp and square edges and parallel faces.
  • Must be homogeneous in texture and emit a clear ringing sound on being struck together.
  • Free from flaws, cracks, chops, stones and lime.
  • Should not absorb water more than 20% of its own dry weight after 24 hours, immersion in cold water.
  • Have a minimum crushing strength of 105 kg per sq. cm when tested according to the test.
  • Should not show appreciable sign of efflorescence either in dry state or subsequent to soaking in water.
 NOTE: As per guidelines of all wings of the Government, semi-Government departments and other construction departments, First Class Brick tiles should be used for construction works.
   Specification of Second Class Bricks
  • They shall be well burnt or slightly over burnt.
  • They must give clear ringing sound when struck.
  • The may have slight irregularities in size, shape and color.
  • They may have slight chips, flaws or surface crack but must be free from lime or kankar.
  • The minimum crushing strength of second class brick should be 70 kg per sq cm.
   Specification of Third Class Bricks
  • These bricks are slightly under burnt or over burnt.
  • They are not uniform in shape, size and edges.
  • They shall not observe water more than 25% of their own dry weight after 24 hours, immersion in cold water.
  • They have some signs of  efflorescence.
Tips for Cement Paint
1935
4244
Selection of cement ..
7542
Brick Advice Urgent
2869
3300
For Estimate
2038
3515
2346
Last answer on 9/19/2012 1:30:40 PM. by r s rawat. Forum started by mujahedsabb
2417
2360
2441
1940
How do I clean cement and brick dust created
Last answer on 8/27/2021 7:09:02 AM. by S L Gupta (Civil Engg). Forum started by Satvinder kaur
3069
we are constructing a new floor Bathroom size is 4ft 6" x 7 ft what kind of po
Last answer on 8/21/2011 7:28:11 PM. by mvnisha. Forum started by kiran
3052
3451
2332
Hi my Name is Riyaj khan i am Marble flooring liver incharge for indian Marble,
Last answer on 7/3/2020 11:34:52 PM. by JAI PRAKASH. Forum started by RIYAJ KHAN
2493
2518
Reg: Cracks in cement brick walls
Last answer on 12/17/2013 12:32:00 PM. by S L Gupta (Civil Engg). Forum started by Dhananjay
103
47
22
21
20
21
21
20
20
21
18
21
22
15
Bricks Quality
What are special types of flooring?
Special types of flooring--Linoleum flooring..............
Brick Arches
Specification of Brick
Brick Pillar
