Wed Feb 16, 2011 | Post #1 | Nikita
Join date: Jan 2011 | Post subject: Cause of seepage and dark stain on exposed walls.
Hello, Srinivasa
The salt present in the bricks and raw material appeals in the form of stain on the exposed surface of wall after getting constant moisture specially in rainy season.
Wed Feb 16, 2011 | Post #2 | Ar. Suresh Kothari
Join date: Dec 2010 | Post subject: subject: Cause of seepage and dark stain on expo...
Hello, Srinivasa this is beause of subsoil water coming up. This water is always salty,hence salt & stain on wall outer surface or inner surfaces appear on wall. due to this seepage of subsoil ater which penetrate up ward during mosoon period,and remove the paint applied on walls.
for this you have to give injection of chemical (chemcial treatment ) to stop the water cominng up.
Ar. suresh kothari
architect & valuer | |
Thu Feb 17, 2011 | Post #3 | srinivasa
Join date: Jan 2011 | Post subject: Seepage & Dark Stains
Thank you so much Nikita & Suresh K. I have just started constructing a house and want to take care not to get this problem 3-5 yrs down the line. What precautions I can take to stop this?
Thanks,
Srinivas. | |
Thu Feb 17, 2011 | Post #4 | Gaurav
Join date: Aug 2008 | Hi Srinivas, as pointed out by Nikita & Suresh, the seepage is due to subsoil water coming up. You can ask your contractor to add a water proofing layer to your foundation walls and use good quality cement.
The dark stains on the top is nothing but dead algae formed during rains. Use a good quality external paint and you will not see these stains on your walls. | |
Thu Feb 17, 2011 | Post #5 | Ar. Suresh Kothari
Join date: Dec 2010 | Post subject: Seepage & Dark Stains
Hi Srinivas,
Mr. Gaurva has rightly said to provided chemical bearier to stop seepage/subsoil water comig up.
first step, when your masonry work comes to G. L. , you provide water proffing chemical layer or black tar layer or thin slat stone/or thin kotah stone layer, which will stop the water penetrating up.
Second step, you provide another layer of black tar/water proofing chemical layer to masory works below the RCC copig layer.
third step, before refilling the soil in trenches, apply black tar/or water proofing chemical to the vertical surfaces,the refill the digged trenches.
This process will complete stop the water coming up & your colour and walls will be safe.
Thaks
Ar. Suresh Kothari | |
Fri Feb 18, 2011 | Post #6 | srinivasa
Join date: Jan 2011 | Post subject: Construction level solution to seepage/dark stai...
Dear Suresh & Gaurav,
Thank you so much for your suggestions. This is of great help to me.
Srinivas. | |
Mon Feb 28, 2011 | Post #7 | megous
ozone layer and adding to the Green House Effect, which is resulting in Global Warming and abrupt changes in climatic patterns all over the world. Scientists, environmentalists, entrepreneurs and industrialists are all evaluating various methods to reduce the effects of industrial activity on global environment.
Galvalume sheets
