Home -> Forums -> Construction -> Bricks -> guide me about low cost material for wall other than brick n all
Tue Dec 11, 2012Total posts : 3
saif
saif
Topic: guide me about low cost material for wall other than brick n all
I want to build house on 2000 sqft area but my budget is low aprox 10 lacs thats y i want to low cost material for all my internal walls.
pls guide me..
thanks
saif ansari
8237776002
Wed Dec 12, 2012Post  #1
Dear Saif
       You should consider your idea about low cost walls, because the cost of land is very high and after some time you have to make another story on it than it is not possible to construct on weak wall.
For low cost wall if stone is easily available than it is cheap than brick walls.
If you have less budget than it is advisable that you construct the house up to roof level and than finish it according to budget availability.
Wed Dec 12, 2012Post  #2
saif
saif
thnx sir but what u think about shera boad walls its vey easy to make wall from shera board and very cheap as well also or sandwicht walls ( prefabricated ) but only internal walls.....
Thu Dec 13, 2012Post  #3
Dear Saif
Shera board walls are partion wall which does not take load of structure, so extra expenditure to be made for making beam under slab so in this way these are not cheap as you want.
The sandwitch walls are costlier than brick walls.
2285
wall
Last answer on 12/12/2012 12:27:36 PM. by S L Gupta (Civil Engg). Forum started by saif
2897
3978
Low cost viila design up to plot area 200 sq.yard only
Last answer on 10/18/2016 5:13:31 PM. by Vijaya. Forum started by Syed Zakir Ali
1806
Tiles
Last answer on 1/11/2022 5:32:54 AM. by Ben. Forum started by Yuwraj
2812
brick calculation
2858
Compound Wall Construction
13675
2257
ceiling fan
Last answer on 12/1/2011 4:29:33 PM. by Alexander. Forum started by sunil
2770
Reinforced brick wall construction
Last answer on 10/11/2011 6:33:52 AM. by S L Gupta (Civil Engg). Forum started by sunny420
2553
cost of plaster a block wall
Last answer on 2/27/2013 10:58:41 AM. by S L Gupta (Civil Engg). Forum started by kamlesh
2584
1529
And how much is labour and material cost to chip old wall and replaster it with
Last answer on 11/8/2017 1:53:56 AM. by S L Gupta (Civil Engg). Forum started by Sheila
9243
3477
Cost of Brick Work
Last answer on 6/4/2014 3:43:02 PM. by S L Gupta (Civil Engg). Forum started by Subhajit Kundu
11666
Brick wall and Lintel construction cost per SqFt
Last answer on 6/7/2015 1:27:14 AM. by JAI PRAKASH. Forum started by DD Gandhi
3052
1994
Over Head Water Tank
3954
2724
type of brick
7542
Brick Advice Urgent
2917
Bricks
2812
brick calculation
2590
Cost of Brickwork
4913
2834
2361
3186
bricks
5683
2041
3264
5145
Use of Solid Concrete Bricks
1645
1360
1864
1495
1817
2976
fly ash bricks
1737
Specification of Brick
Buying
Buying Guide for Garage Door
Brick Arches
