cellular lightweight concrete
Thu Aug 06, 2015
Karma Tenzin
Topic: cellular lightweight concrete
Can anybody gives me the complete process of plastering on the CLC wall including the ratio of cement and sand used and the required thickness of plaster?
Fri Aug 07, 2015
‘Plastering’ is the finishing coat which provides a good look and improves hygienic conditions in the building.
Before starting the plaster reference marks (BUNDAS) should be made on the wall in 2” to 3” dia.
Plastering is done with cement and sand mortar. It consists of different thickness as per requirement of the site.
Plastering is done by applying cement mortar with required ratio i. e. 1:3, 1:4, 1:6 on the walls and the plaster should be in straight line, level and plumb and the joint must be in right angle.
The surface to be plastered should be racked out and cleaned with wire brush. It should be made wet 24 hours before starting the plaster.
All the doors, window frames, electric fittings and water supply lines must be fitted before starting the plaster and they should be laid as per drawings.
Care should be taken that unwanted cement mortar on the frames and electric fittings should be cleaned immediately after finishing the plaster.
Proper curing should be done at least for 7 days after the plastering is complete as it is the most important factor for maintaining the strength of plaster.
1575
Last answer on 6/7/2017 12:20:58 PM. by
Sandeep Vidwans
2959
Lightweight Concrete Roofing
Last answer on 10/31/2012 12:32:07 PM. by
Ted Junior
1784
vishal Thakur
1477
vishal Thakur
2158
It looks like a lightweight, small-size tub that would fit in my existing bathro
Last answer on 3/19/2012 7:39:47 PM. by
Elisabeth Khan
Elisabeth Khan
3482
Cost of concrete walls
Ar. Manoj Ralen
Ankur Kothari
20195
Last answer on 2/18/2022 6:35:57 PM. by
SusanBones
mani
2241
zero slump concrete
Malik Usman
1814
Last answer on 3/1/2015 8:08:06 PM. by
2180
Last answer on 5/25/2018 12:47:44 AM. by
Raghavendra
3454
amit yadav
amit yadav
3298
Last answer on 10/12/2014 9:03:20 PM. by
rajeev
3786
Last answer on 7/4/2020 2:12:02 AM. by
Priti Arora
farid
3816
concrete mix design software
Last answer on 1/21/2021 9:34:10 AM. Forum started by
Robin
2268
sand alternate for concrete
Last answer on 10/9/2010 11:37:42 AM. by
G N Shaikh
manohar
2040
parts of concrete and size.
Last answer on 3/15/2011 6:16:45 PM. by
kanwer sajjad
2292
swarup chakraborty
2439
roof concrete
Last answer on 5/22/2014 1:50:02 PM. by
sakthi
2433
Last answer on 10/12/2014 8:50:05 PM. by
sakthi
5847
Rakeeb Rathor
3820
Pandu
9912
nasad
2687
Sreedhar
4640
ani
4156
Anamika
2892
lio
5245
ringwang
R.Roy
5081
MANISH
3683
Arvind Bhaskar
4091
premkumarlen
1876
carmenjames
r.n.misra
2816
Sharath Kurva
Sharath Kurva
2624
gk
2412
Adriano Peres
vamsi
2484
nuksung
2651
dayal
1823
TUNDE
3634
ragha
6282
suba
Concrete Decor
Concrete Mix Ratio
Ready Mix Concrete
Tips for Cement Paint
