Thu Nov 19, 2009 | Total posts : 4 |
| Topic: cost of plumbing,sanitaion,electrical as %of civil work
1.my contractor is charging 15%over cost of civil work for plumbing and sanitaion. an additional 15% for electrical. have attached the specs.
is this correct?
2.total area to be built for a first floor of house-1765sqft
civil work-14lakhrs, joineries i.e doors,windows - 6.7lakhs teak wood being used and french doors is being charged at rs1200 per sqft, 3.3lakh finishes i.e tiles
are french doors so expensive. are the other costs ok |
Fri Nov 20, 2009 | Post #1 | Karan
Join date: May 2009 | Post subject: Need deatils for verification of cost
Dear Naina
It would have been better if you give more details like place, construction work has been started or not, architectural plan of house otherwise it may vary cost of construction.
Karan
Fri Nov 20, 2009 | Post #2 | naina
place is chennai,work not started,plan attached | |
Fri Nov 20, 2009 | Post #3 | naina
Fri Nov 20, 2009 | Post #4 | muralibgowda
Join date: Apr 2009 | Hi Naina, I dont see the plan attached. Regards, Murali
Articles that might interest you! | | Brick Work Brick work is an important part of construction work done with the help of bricks and cement mortar. It is done with d.. | | Checklist for Painting Work Before you start paint work, make sure that the surface is clean of dust, grease and other foreign matter. Decide on s.. | | Preliminary Works during Ground Work Entire area should be cleared of all roots, bushes, vegetation etc. for a smooth construction works. | | Surface Preparation and Painting Tips Paint is any liquid, liquefiable or mastic composition which after application to a substrate in a thin layer is conve.. | | Water Supply and Various Types of Pipes Water is essential for everybody. In home or workplace we need a systematic placement of pipelines for water supply. W.. | | How to hire a plumber To find a skilled plumber you have to do enough searches for it. Contact friends and relatives for a skilled plumber a.. | | Bath Fixtures Bath fixtures include showers, bathtubs, sinks, toilets, lighting fixtures or bathroom mirrors. In the era of stylish,.. | | Guideline for Labor for Brick Work Foundation We all know the importance of brickwork in any construction, So the article here describes the guideline meant for la.. | | Guideline for Labor for Brick Work in Super Structure While going for construction, do we know the Guideline meant for Labor for Brick Work in Super Structure? If not then .. | | 10 things to check before the rain hit your home! Rain is fun but the fun may not last if your home fails to protect itself and its occupants from the elements. This wr.. | | What are various types of glasses used in doors? Types of glasses used in doors-Clear window glass, Plate glass, Prism glass, Quartz glass, Processed glass....... | | What are advantages and disadvantages of folding doors? Advantages of folding doors- Easy to install,washable, durable, superior sound damping. Disadvantages-sensitive to har.. | | What are various designs available in wooden doors? Designs available in Wooden doors..... | | What is standard size of internal folding doors? Size, Thickness and Weight of Internal Folding Doors....... | | What affects the life of doors? What can we do to increase the life of the Wooden doors? Tips to increase the life of Wooden doors.... | | What is the standard size of frame for Plastic/PVC doors? Plastic Door frame size carrying one or two shutters...... | | What are various frames recommended for Plastic/PVC doors? Frames for Plastic Doors.......... | | Which place is appropriate for sliding door? Appropriate places for sliding doors-Bathrooms, Backyards, Commercial structures........... | | What are various frames recommended for glass doors? Frames for Glass Doors-Wooden frames, Steel frames, Aluminium frames...... | | Which place is appropriate for folding doors? Appropriate places for folding doors-Homes, Offices, Guest rooms, gives attaractive and stylish look........ | | What are the various accessories recommended for folding doors? Accessories for folding doors- Door Handles, Door Fasteners,Door Viewers....... | | What affects the life of doors? What can we do to increase the life of the Plastic/PVC doors? Tips to increase the life of Plastic doors.... |
