Home -> Forums -> Construction -> Cement Concrete -> Concrete Mixture
Concrete Mixture
Mon Sep 03, 2012Total posts : 2
Navneet Shahrawat
Navneet Shahrawat
Topic: Concrete Mixture
Could you please educate as to what is M20, M25, M30 in concrete mixture ratios? What grade should be used for columns and beams and for slab in Gurgaon?
Navneet
Tue Sep 04, 2012Post  #1
Post subject: Ratio of Sand , Cement and Crusher stone for M20...
Dear Navneet,
 M20 and M25 is the Mix ratios of Cement, Sand and Crusher Stones (which can be used for construction).These are grade of cement concrete.
In M20 concrete mix the ratio of cement concrete is 1:1.5:3 i.e. 1 part of cement, 1.5 parts of course sand and 3 parts of bazri ( stone ballast 12mm to 20 mm).
In M25 concrete mix that the ratio of cement concrete is 1:1:2 i.e. 1 part of cement, 1 parts of course sand and 2 parts of bazri ( stone ballast 12mm to 20 mm).
Tue Sep 04, 2012Post  #2
Ar. Manoj Ralen
Ar. Manoj Ralen
Dear Navneet,
Structure engineers study the soil load bearing capacity, the load of the building, span (length) of the rooms to come up the location and size of pillars, foundations etc. In that drawing you will also find specification of concrete to be used in each part.
thanks
6506
2476
Readymix Concrete Mixture
Last answer on 8/17/2012 12:01:44 PM. by jmahajan. Forum started by Navneet Shahrawat
3638
Per Sq:ft rate for flooring
1887
Roof Painting
1819
Need Advice on Solid Wood Floors
Last answer on 4/30/2014 8:29:12 PM. by Abhishek Garg (Builder & Engineer). Forum started by chintan arora
3227
Natural Stone Design
Last answer on 2/20/2022 12:24:13 AM. by leelindsey. Forum started by Swarup Kumar Dey Choudhury
1784
1477
3481
Cost of concrete walls
20195
2240
zero slump concrete
1813
1642
3454
2040
parts of concrete and size.
Last answer on 3/15/2011 6:16:45 PM. by S L Gupta (Civil Engg). Forum started by kanwer sajjad
2267
sand alternate for concrete
3784
3481
1814
STP
3120
3668
4371
rate comparison
3164
sloping roof
2105
15932
6493
2405
leakage in new slab
1560
Guide me
5208
2549
Civil Eng Stair Design
2549
2351
Related to Sunken Slab
1878
2020
Concrete Hollow Block Masonry
2438
roof concrete
3217
Ready Mix Concrete
Concrete Decor
Concrete Mix Ratio
Ready
Ready Mix Concrete
Tips for Cement Paint
