Construction in Palampur, HP
Wed Apr 02, 2014
Sanjay
Topic: Construction in Palampur, HP
I like to understand what is the possibility and approximate cost of building a house in Palampur, HP (2 bedrooms 150 sqft each with attached baths on upper floor and 1 drawing/ dinning room - 20 x 30 sqft + 1 guest room/ office with attached bath on ground floor.
All Granite slabs and fully seasoned wood. Flooring wooden across house with some marble or granite tiles if needed.
Living room with large 10 ft x 8 ft glass Windows. Similarly larger full scape windows for bedrooms.
I like to know what is the investment range from lower (minimalistic approach) to above average quality construction and the time needed.
Wed Apr 02, 2014
Dear Sanjay
For cost detail estimate, plan of the house, specification used, elevation drawing is needed. If you want tentative estimate than use COST ESTIMATOR AT website gharexpert.com. If want detail estimate see the link below
1781
My plot in city paonta sahib HP 17302939*45 ft I want's to a good vastu shastra
Last answer on 10/14/2021 8:51:31 AM. by
Anil Kumar
2796
suction pipe length for sump motor
Last answer on 1/5/2022 8:30:40 PM. Forum started by
manjuks
3646
Wall unit
Last answer on 2/16/2022 7:56:28 AM. by
BobYoung
brucecobbins
2775
Submersible pump - Bore
Last answer on 5/25/2010 6:03:31 PM. by
Giri
23895
Last answer on 7/8/2020 10:27:10 AM. by
sonu
6126
What is construction cost
Last answer on 12/1/2020 5:38:30 AM. by
manoj
2044
Last answer on 7/3/2020 10:54:45 PM. by
zakia sultana
2318
Last answer on 2/22/2022 2:58:13 AM. by
Vishal
3107
Last answer on 12/14/2020 9:46:53 PM. by
Mubarak Khan
1806
Last answer on 3/17/2021 12:53:46 PM. by
MD KAMIL RASHID
1891
Last answer on 4/12/2021 12:56:27 AM. by
Yousuf
1765
Last answer on 7/4/2020 4:27:11 AM. by
Anu Mohan
1606
Hi, My Name is mustkeem I m from Paonta Sahib, Sirmour HP, I need a Plan. My po
Last answer on 1/10/2016 9:05:18 PM. by
Mustkeem
5808
Last answer on 8/20/2020 3:44:33 AM. by
mayank
2371
Last answer on 4/11/2013 11:08:41 AM. by
suresh
3903
Last answer on 9/22/2021 6:50:36 AM. by
Last answer on 2/20/2022 12:56:30 AM. by
zahir
4987
Last answer on 6/24/2021 1:12:48 PM. by
sunny420
6485
Last answer on 6/25/2013 11:09:36 AM. by
kumar gautam
2493
