How to design my house to be more flood and earthquake safe.
Fri Aug 31, 2018Total posts : 1
Betty Varghese
Betty Varghese
Topic: How to design my house to be more flood and earthquake safe.
Wed Sep 05, 2018Post  #1
Important Points for Construction
• Before starting a new construction project, check whether your area comes in a Earth Quake prone zone. While doing construction work safety measures should be taken for earth quake protection.
• The whole area of the building should be constructed at one time to avoid settlement in any portion of the building.
• If the construction is done in small portions, there may be chances of the settlement in foundation.
• All components of the building should be tied up with R.C.C. Band at plinth level/DPC level, door lintel level and roof level.
• The corners, T-joints and balcony should be designed keeping in view the safety.
• Keep in mind the norms/rules of concerned area about building construction.
• Know about the authorities whose sanction is required to start the construction work.
• Know how much time it will take for getting the sanction.
• Search for a qualified architect or designer.
• Prepare house plan according to the area of the plot.
• Arrange structural drawing according to the type of soil.
• Know availability of the building materials, their quality and reputed material suppliers.
• See the availability of good quality of water and availability of electric connection.
• Access the labor/contractor for construction.
• Have knowledge about high flood level and the level of surrounding buildings and roads
Works while Starting Construction
While starting the construction work by contractor at site after approval of the drawings and designs, the following works should be taken in hand.
• The site should be cleared if roots of the trees exist; they should be removed up to 2 feet below the ground level.
• Layout of the building should be done with fixing centre lines and 'burjis' or brick pillars etc. and mark all the walls, columns on the ground with their proper length and width as per designs or drawings.
• Plinth level/DPC level should be fixed keeping in view the H.F.L (High Flood Level) and surrounding buildings and nearby roads.
• Excavation for foundation should be done according to the designs and exact width and depth of the wall should be dug. If extra depth is made due to any reasons or any soft places found, those should be filled in with coarse sand or concrete.
• In case of excavation made through J.C.B. machine, the last layer should be done manually to avoid softening up to the base of foundation.
• In case the water comes in trenches, it should be pumped out immediately.
Concreting
After dressing the side and bottom of the trenches, the cement concrete, mechanically or hand mixed should be laid in trenches.
The concreting should be done in 6 inches layers and should fully be compacted with vibrator or hand rammer.
• Brick works should be done according to drawings or designs in foundation.
• The bricks should be of the Ist class quality and they should be soaked in clean water by spraying.
• The joints of brick works should be filled up with mortar completely.
My house was flooded during the recent flood, what should i do to check structur
Last answer on 9/5/2018 1:28:37 AM. by S L Gupta (Civil Engg). Forum started by Malini R
3258
1688
earthquake safe building
Last answer on 5/12/2015 2:55:33 AM. by JAI PRAKASH. Forum started by ARVIND GOYAL
2769
1116
Are TMT's building really earthquake resistant
Last answer on 8/20/2018 12:14:24 AM. by S L Gupta (Civil Engg). Forum started by Anu Mohan
1526
1057
Where is it profitable and safe to exchange cryptocurrency?
Last answer on 12/6/2021 7:24:25 AM. by Alexander Graf. Forum started by aglar
799
Where is it more profitable and safe to exchange cryptocurrency?
Last answer on 11/21/2021 5:14:42 PM. by Vaasku. Forum started by agribalt
598
What Are the Components of Safe Forex Trading?
Last answer on 12/27/2021 12:36:06 PM. by aglar. Forum started by segment
2249
Sir I want east facing 21.3×48 house plan design's
Last answer on 3/5/2016 10:38:30 PM. by JAI PRAKASH. Forum started by Venkat
2346
Very good design send 700sqft house design and estimate with plan My e
Last answer on 4/4/2015 7:09:15 PM. by JAI PRAKASH. Forum started by ayyakannu
2832
some more contemporary designs along with execution details i am looking for on
Last answer on 1/2/2021 5:27:19 AM. by Priti Arora. Forum started by deepti mangla
9564
Earthquake Design - Plinth Band and Lintel Band
Last answer on 12/31/2020 2:02:44 AM. by Love thy community. Forum started by Kitan
2858
Am looking out for some latest designs of TV units and portrait display tables
Last answer on 7/9/2021 7:38:00 PM. Forum started by RVkamat
3728
i am looking forward for a book of interiior designing preferably wth pictures o
Last answer on 7/3/2020 11:11:57 PM. by Nikita. Forum started by ravi
2748
I AM LOOKING FOR POOJA ROOM DESIGN
Last answer on 7/3/2020 11:01:33 PM. by S L Gupta (Civil Engg). Forum started by JAGDEO PANDIT
1697
3700
110
48
17
24
21
20
21
21
20
20
22
18
21
20
22
15
Earthquake
Orientation
Orientation of Building
How to design a house on theme
Theme designing is slowly but steadily picking up steam. Designers today are very particular about the 'idea' behind a s
Earthquake
Earthquake safety tips
Earthquake can strike suddenly with very little warning. One minute you may be enjoying the company of your kids and f..
Painting
What
What is recommended size and shape of building for the protection in earthquake prone areas?
All parts of a building should firmly be tied together and stiffly braced at corners in such a manner that the whole s..
