Thu Aug 28, 2014
ADINATH
Topic: load bearing walls vs column frame construction
can a ground plus one with sloping terrace be built without rcc columns ?
Fri Aug 29, 2014
yes
2630
COLUMN nd LOAD BEARING
Shivaraj
Shivaraj
10085
manishkumar
manishkumar
2278
Last answer on 5/3/2016 12:27:42 AM. by
navneet
7311
Last answer on 7/4/2020 2:54:21 AM. by
gautam kumar
6546
Load Bearing vs RCC frame
Last answer on 7/3/2020 11:34:17 PM. by
DK
2242
Last answer on 9/14/2021 5:43:01 AM. by
neha
1787
Last answer on 2/3/2022 7:29:44 AM. by
Akhil George
3955
Last answer on 2/15/2013 11:15:40 AM. by
prassant kumar
prassant kumar
4165
Last answer on 1/6/2022 11:48:27 PM. by
2318
RCC Framed Structure: Sequence of constructioin
Last answer on 12/27/2014 3:22:06 PM. by
Arvind Bhaskar
2546
Last answer on 5/16/2021 2:27:15 PM. by
bhaskar
8873
Last answer on 10/15/2014 1:52:38 PM. by
Ambuj
3557
Installation of solid load bearing granite/sandstone columns.
Last answer on 4/19/2012 12:05:30 PM. by
Rajan S.Raj
Rajan S.Raj
5043
Last answer on 1/3/2021 2:57:44 AM. by
2143
Load bearing
Last answer on 1/17/2014 12:05:30 PM. by
Syed Shahed
1756
Last answer on 4/25/2016 3:26:07 PM. by
VIKAS KUMAR
1751
3948
load bearing walls
Last answer on 12/7/2020 12:04:44 AM. by
mohan
mohan
1817
2493
Specification of Steel
Door and Window Frames
