Home -> Forums -> Construction -> Door Frames -> Column Size and distance
Fri Apr 03, 2015Total posts : 4
Saksham Gupta
Saksham Gupta
Topic: Column Size and distance
I am attaching the CAD and PDF Plan of my commercial project. Kindly suggest me the appropriate size of the columns and beams with Bar specification. My requirements are as follows :
1.  Ground Floor Height - 16'
2.  Total Building Height - 40'
3.  G+2
4.  Plinth height - 4'
Thanks,
Saksham Gupta
Assam
+91 9854001122
Attachments: Commercial Drawing CAD 1.dwg on Fri Apr 03, 2015,
PDF Final 1.pdf on Fri Apr 03, 2015,&n
Fri Apr 03, 2015Post  #1
Dear Gupta
        It is better if you have structural design from structural engineer. How ever keep the column size 12''x 18'' with 8nos 16 mm dia bars and beam size may be 12''x15'' below roof slab with 4nos 20mm dia and 2 nos 16 mm dia bars wit 8 mm dia rings @ 6'' c/c. Use cement concrete mix as 1;1.5;3.
Fri Apr 03, 2015Post  #2
Saksham Gupta
Saksham Gupta
Post subject: Column Footing Net
It'll be very kind on your part if you can also suggest me the right size for Column Footing net.
Thanks,
Saksham Gupta
Sat Apr 04, 2015Post  #3
Dear Gupta
         In my view the footing of outer columns should be 5'x5' and middle column should be 6'x6' with 12mm dia steel bars @ 6'' c/c on both ways.
Sat Apr 04, 2015Post  #4
It has to be given by the Architect.
Door Frames -Construction Questions (32)
3812
15818
2733
6585
2114
3984
For G 2 residential building, column size 9"*15",16mm 4rod,12mm 2rod used.. hori
Last answer on 7/4/2020 2:29:23 AM. by S L Gupta (Civil Engg). Forum started by Sathya
9046
6504
Column placement for house
3037
1545
Is it necessary to leave 3feet distance as a front setback in house plan or we c
Last answer on 10/10/2017 12:39:29 AM. by S L Gupta (Civil Engg). Forum started by VIPUL BHALDE
9270
pillar size in distacce
5244
3535
4674
What is the RCC column size for 20 feet distance for two floor house.These 20 fe
Last answer on 2/23/2014 8:38:52 PM. by Navneet Jharia. Forum started by somvir
8979
Last answer on 9/11/2020 2:17:26 AM. by hemant. Forum started by hemant
2967
Need suggestions
2177
design of column
2809
4671
4752
3237
29220
wood calculation
Last answer on 1/5/2022 2:17:35 AM. by Navneet Jharia. Forum started by agg
5043
1686
outside main gate
Last answer on 11/17/2020 12:09:44 PM. by S L Gupta (Civil Engg). Forum started by Pooja
4116
need little calcultaion
Last answer on 7/4/2020 12:03:17 AM. by JAI PRAKASH. Forum started by gaurav
2704
DOORS
10499
1753
1906
door frame height
Last answer on 12/29/2015 12:49:44 AM. by JAI PRAKASH. Forum started by Pooja
2091
3006
Door window frame
Last answer on 12/16/2013 9:13:21 AM. by . Forum started by Purvi Panchal
3499
Last answer on 3/4/2013 6:35:55 PM. by S L Gupta (Civil Engg). Forum started by P. Panchal
Right size cupola
What is binding wire
