CONCRETE MIX
CONCRETE MIX
Thu Sep 22, 2016
Topic: CONCRETE MIX
I have agreed with my buildjng contractor M15 Cincrete 1:2:4 for my home construction ground +1..total 2500 Sq ft...
now actually at site.. contractor goes this concrete ratio of 1:2.5:3 against agreed 1:2:4...he explains there is a practicality problem to get the proper mix to use.. Though as per my understanding over all actual volume ratio comes lower 6.5 against agreed 7..it looks better...however i would like to have your expertise opinion on this..should i agree this ...please share your opinion...
Thanks / Regards
Prabhu.M
Sat Sep 24, 2016
Dear Prabhu
The course sand quantity should be 50% of the bazri or stone chips for standard mix. The contractor increases the sand ratio for easy work to finish and might be sand cost may be less than bazri. The strength of 1;2.5;3 is less as compare to m15 or 1;2;4.
Sun Sep 25, 2016
Thanks Sir...
3813
concrete mix design software
Last answer on 1/21/2021 9:34:10 AM. Forum started by
Robin
Last answer on 10/12/2014 9:03:20 PM. by
rajeev
1696
Last answer on 5/3/2016 12:53:30 AM. by
K M Sendhil
3399
1:2:4 mix or 1:3:3 mix
Last answer on 3/18/2014 1:08:38 PM. by
navneet
1783
vishal Thakur
1476
vishal Thakur
3164
sloping roof
Last answer on 7/4/2020 2:00:34 AM. by
ekonagu
2476
Readymix Concrete Mixture
Last answer on 8/17/2012 12:01:44 PM. by
jmahajan
Navneet Shahrawat
6506
Last answer on 7/3/2020 9:28:50 PM. by
junkie9411
George Kattapuram
2571
Water for Construction
Last answer on 3/31/2010 6:05:23 AM. by
nuwan77
2160
seal coat on roof
Last answer on 9/19/2010 11:16:18 PM. Forum started by
viswanath
1468
Is the concrete mix ratio M20 (1:1.5:3) weight based? If yes, whether volume based 1:2:4 ratio is almost equal to M20?
Last answer on 3/10/2017 12:37:18 PM. by
2854
Last answer on 10/27/2015 11:40:05 AM. by
Karuna
2914
Terrace water proofing
Last answer on 7/13/2020 12:26:53 AM. by
ravi pachipala
2493
Last answer on 11/17/2015 8:51:17 PM. by
Techman
4395
Ready Mix Concrete
Last answer on 12/31/2020 2:22:24 AM. by
Girish
Girish
2169
Ready Mix Concrete
Last answer on 7/4/2020 2:18:20 AM. by
Vishwanath
3217
Ready Mix Concrete
Last answer on 10/7/2013 11:24:46 AM. by
sck
4381
WHAT IS THE RATIO
Last answer on 12/17/2010 11:24:47 PM. by
santosh kumar
S.BHUPAL RAJU
2493
Concrete Mix Ratio
Ready Mix Concrete
Concrete Decor
