Cement
Wed Apr 09, 2014
shaik khaja nayab rasool
Topic: concrete work stop at in middle
hai..sir if any concrete work (retaining wall,slab,column,footing etc.....) it is happen to stop the work.. for any reason but what is our responsibility as a engineer to start the work to next day means precaution to take and also at what stage only we stop the work
Fri Apr 11, 2014
Dear Rasool
The concreting in beam should not be stop in midway, in case of slab it should be stopped on the middle of wall or middle of beam. Next day starts the work after curing the old work after applying the cement shullary on the old joint.
4474
lobar work quantity
Last answer on 2/21/2021 12:21:16 AM. by
D A VRAO
2433
Last answer on 10/12/2014 8:50:05 PM. by
sakthi
11622
Last answer on 3/25/2010 6:08:56 PM. by
ch jaya bharath azad
shridhar
3145
Last answer on 8/27/2015 6:46:22 PM. by
1820
Last answer on 7/4/2020 2:32:26 AM. Forum started by
shivam gupta
780
I am looking for a good SUV for all family of middle size
Last answer on 7/9/2021 8:32:03 AM. Forum started by
Simon
3417
Bathroom Cleaning Tips
Last answer on 6/10/2019 1:04:58 AM. by
jaswinder Singh
Nitesh Patel
6640
Last answer on 1/7/2022 1:25:49 AM. by
Girish
Girish
2589
Last answer on 7/16/2012 11:45:56 AM. by
George Kattapuram
1842
Last answer on 7/3/2020 11:35:37 PM. by
Ganpat B Chaudhary
1784
vishal Thakur
1477
vishal Thakur
2156
how do you stop dampness in old buildings especially if it is due to burst conce
Last answer on 11/13/2010 8:21:32 PM. by
sangameshs
3864
Last answer on 6/16/2015 4:28:50 AM. by
aladin
2954
Last answer on 10/5/2016 11:34:14 AM. by
arun
arun
3121
Last answer on 10/5/2020 10:59:59 PM. by
DEVANSU
2069
It need to thinks for middle class people with innovative ideas to build such ty
Last answer on 12/12/2010 12:25:15 AM. Forum started by
S Borthakur
3481
Cost of concrete walls
Ar. Manoj Ralen
Ankur Kothari
2474
I have a 2000sqft east facing middle plot. pl send me a planning for 3bd design
Last answer on 4/22/2014 2:31:59 PM. by
kishore ku patra
1689
Cement requirement
Last answer on 1/5/2022 12:58:42 AM. by
Yousuf
1807
RAW MATERIAL
Last answer on 9/20/2021 1:41:45 PM. by
sumit
3461
Type of Cement
Last answer on 4/22/2021 5:20:49 AM. by
sumit dua
2542
RCC Slab -Curing
Last answer on 3/25/2021 4:28:26 AM. by
Arvind Bhaskar
2353
Materials
Last answer on 3/2/2021 6:29:44 AM. by
UMinesh
23846
Last answer on 2/17/2021 4:49:34 AM. by
2886
Types of Cement
Last answer on 12/31/2020 2:12:10 AM. by
Sonika
shivakumar
2530
Cement
Last answer on 7/2/2020 10:15:16 PM. by
ferous
2751
Per Square
Last answer on 6/23/2019 11:56:29 PM. by
kiran kumar 3k
1292
Last answer on 11/2/2016 11:29:57 AM. by
2003
Cracks in concrete roof
Last answer on 8/24/2016 4:18:27 PM. by
Dhanush Ahuja
Aarav Sharma
1254
Last answer on 5/26/2016 12:44:58 PM. Forum started by
SUNIL KUMAR
1766
Last answer on 5/25/2016 11:08:08 AM. by
Dev
2293
Cement selection
Last answer on 5/3/2015 7:49:23 PM. by
ashuu
1886
Economical cement brand
Last answer on 2/22/2015 7:02:19 PM. by
Bhuwan
Bhuwan
2922
Cost of Cement Plaster
Last answer on 6/4/2014 11:32:31 AM. by
Subhajit Kundu
2495
Cement and Grades
Last answer on 6/13/2013 2:45:08 PM. by
MANJUNATH
3060
Last answer on 3/19/2013 12:28:05 PM. by
HARISH
2446
Past Prices
Last answer on 11/23/2011 10:23:47 AM. by
ravi at Dalmia
Hemanth
What are various types of panel doors?
Single panel, Double Panel, Three Panel, Six Panel doors........
What are various types of valves for water pipe lines?
Valve is suitable means of connections for inserting and controlling the flow of the water.Nominal size of stop valve ..
Concrete Decor
Concrete Mix Ratio
Designing a Foundation
Ready Mix Concrete
Checklist for Painting Work
