Home -> Forums -> Construction -> Pillar Work -> RCC column (pillar)
RCC column (pillar)
Tue Sep 20, 2016Total posts : 1
bibhas naik
bibhas naik
Topic: RCC column (pillar)
Sir
My contractor didnot use vibrator
for filling concrete inside column  (pillar)
Is it a big problem?
Sat Sep 24, 2016Post  #1
Dear Naik
         The strength of column filled without vibrator is less than the column filled with vibrator. But do not worry if the column is filled with proper concrete mix and ramming by steel rod or bamboo.
2445
start construction Steel use
2734
4404
2109
in concrete piller using more cement sand than20 mm jelly what is the result will be?
Last answer on 5/19/2015 9:17:17 PM. by JAI PRAKASH. Forum started by manja nayka k r
2114
4469
2551
3027
5244
3955
9911
2617
Renovation of old house
Last answer on 5/24/2013 5:06:03 PM. by chandrakanth. Forum started by chandrakanth
18470
4611
Reagarding Coulmn Pillar
Last answer on 9/29/2015 11:01:46 AM. by S L Gupta (Civil Engg). Forum started by Amit Kumar
4420
1922
foundation type confusion : pls suggest
Last answer on 12/18/2015 11:22:33 AM. by S L Gupta (Civil Engg). Forum started by sushantsah
1859
SLAB LOADING
Last answer on 12/24/2015 4:05:10 AM. by JAI PRAKASH. Forum started by ANISH
2197
New column footage and pillar very next to the wall of existing building
Last answer on 10/30/2014 5:27:13 PM. by Rachael Suggs. Forum started by Robert
3478
What is gap to maintain in Plinth/beam/Pillar/roof/Chejja
Last answer on 11/10/2016 5:26:49 PM. by S L Gupta (Civil Engg). Forum started by sam_m400
32644
Cost of RCC Pillar
6454
position of pillars
1895
column
1797
First floor plan suggestions
2539
Pillar cost
4077
42149
12514
First floor construction
2520
2516
Length of cantilever beam
9272
pillar size in distacce
9243
2835
2009
2218
3179
Laping length requirement
Brick Pillar
Type
